Okay lets start off with the basices on what these can do and how they work
All of the Games use something to render the game window, this is but not limited to d3d8, d3d9, Gdi, and openGL
You can use a programe called "Depenaicy walker" To find out if the target game is one of these, check what d3d Version it uses, if it uses d3d9, LIKE MOST TTX games AWSOME
You can use These files to force the game into a Window.
You Copy over D3d9.dll Settings.arc and window.dll this dll
https://mega.nz/#!RpZVgLhQ!0DU5z1z3pivoV8K0iudVDm6oW6-p1mJip9uNFiH2eqo
Why do you want your game to be in a window you might ask?
Rotation playing shumps in Yoko mode,
Running 4:3 games aspect correct on a 16:9 Screen
You can also cheese certain gpu vendor specifc things with custom hacked dlls such as visual bugs in games such as DS2, SSED ECT
How dose it work? how to I move my game form this window to a fakefull screeen?
Few methods Really But the best way in my option is autohotkey, NIrcmd also works
So here is a "baseloader + resizer" Iv made.
https://mega.nz/#!xxQGEKwD!Z_H9ZdUaRwL0mhSd4qWfs5_-H7IZ6kGu65OMpUzpQb0
You need to copy the files out of it + the Windowed mode files you place these inside the games folder Now load the game.exe , once this game looads take note of the "window" title bar
And also ensure the game is working in this force windowed state once this is done open up loadingsettings.ini
You need to set
EXETORUN= to the game you are trrying to run so for a real TTX this would be
EXETORUN="game.exe"
if you are running on a windows pc
EXETORUN="typex_loader.exe game.exe"
Then down at the button you can see
WindowTitle= We need need to set this to the title of the window Example
Windowtitle=Blaz Blue
Once you have this save and now click on loader.exe this should now load the game, once the game becomes active resize it to the proper size its not 100% beacuse i havent tested on every screeen resolution but the tool works very well in all the uses I have
this also adds boarder support by drawing a background by default it is the bg.png thats all black you can supply any image and have it displayed behind the game.
The "esc" key will now close the window and the ahk scirpt giving a clean exit.
Pre- Setup packs For use with PC to use these on a real ttx, you must edit loadersettings.ini
and set it to game.exe so it dosent auto load with typexloader
https://mega.nz/#F!sgIwmSBb!Ld_Aj0DappLptusapwjC1w
Games inside this folder
PC Titles
Yatagauru attack on cata
Akatsuki blitzkamf
Axel City
GundeadLinge collection
Exceed collection
gleam of force 2
Gulity gear XX reload
TTX title
Arcana Hearts 3
Blazblue CS1 + 2
Battle Fantaisa
Deamon bride
Gigawing Gererations
Kof 98 maximum inpmact
Kof skystage
Power instinct 5
Raiden 3 + 4
Spica Adventure
Trouble witches
SSFIVAE Koyo mod.
Shikigama No Shrio 3
