Eddie Amsel
I would for sure be in for a print. You’re in the Netherlands right? How much do you think a set will be?You are correct, need to print it on the actual brushed aluminium foil. Found a good match so that is no problem.
I plan to print it with two layers, a base white and the red on top for opacity. If I do that the red looks normal, as if printed on white vinyl.
If I don't use a base white underneath the red will indeed look more metallic from aluminium vinyl.
So all depends on what finish we are looking for but both are possible and not that expensive.
I print all myself by the way, don't outsource anything. I have the equipment to print white.
