CPS2 - A board, restoration from death to life!
Raph_friend
Amazonia, Japan
The client alleged that the PCB had problems with the graphics and no sound.
I tested the board and it just show me static garbage screen, for this only reason I continued the repair, as it means that something still works.
I separated A and B boards and noticed that the cases had a liquid on it, just like when B board has a leaking battery. I did check it and there was no leakage. Tested on another A board and everything was fine, excluding problems on B board. I removed the battery just in case.
Going for the A board restoration, its case was also dirty with liquid, looking like leaked lithium, however, was alot, it even looked like water. I unscrewed the case, I came across this:
Holy mother of Jesus! I ALWAYS see PCBs that come with batteries installed in place of the SUPERCAP, but I didn't imagine they would reach this point. Until then, I was used to see something like this:
Okay, let's see what can be done.
I removed the initial layer of dirty and dried the liquid that was spread over the board and installed the supercap, which should have been done since the previous "maintenance".
When I see garbage graphics problems on A boards, I always replace the LS157 below the CUSTOM DL-0921 one by one (7U, 7V and 7W) starting at 7W. On the first, game has already started to present graphics but no colors, I changed the other two and the color palettes came back, but still with graphics problems.
Inspected the PCB again, and there was some strange traces near the CN4 socket and one going towards the 3W LS157 was damaged. When restoring, a few more data lines were appeared on the screen.
I left it testing for a few minutes to see if something new was happening. The board started to rebooting.
After another inspection, I noticed some broken tantalum capacitors and the large capacitor in the 12V line of the sound circuit was a little “fat”, I decided to replace these.
The reboot problem was solved, so I back for the rest of the graphics problems.
On the solder side, a broken trace was found near a capacitor's pin solder point, and, to prevent a short, I decided to leave a jumper simple jumper (I could leave it straight, but prefer to keep the original trace form).
Testing a game (Marvel Super Heroes) it show perfect graphics, now, time for the sound circuit, which was totally non-functional.
I admit that A board was still unknown to me. A few years ago I studied it a lot, but without a schematic and block diagram, that we have today, it was really hard to learn. In fact, I thank to Loïc * WydD * Petit, for his wonderful service, which can be seen at https://gitlab.com/loic.petit/cps2-reverse.
First, volume and test switches, it didn't work. I opened everything, cleaned it, and closed them again, perfect.
The continuity of the switch signal was reaching the kick socket, but not the volume control IC.
There's something in common on these PCB that are not so well taken care of, which is this specific damage at the edges of the board and it brings bad traces. After repair, the volume, at least, increased and decreased, but still without sound.
After analysis, I decided to replace the ICs related to the reception and direction of the sound signal to QSOUND. Starting with 2P LS374, which, in resume, is a buffer for the high / low impedance signal coming from board B. The sound came back, but all strange, a little metallic, so I replaced the neighbor 2R LS374 and the sound normalized, but after a few seconds, it stop and repeat the last note played. Looking the documents again, I replaced the 5S LS245, since the function of this CI (in its project) is to manage data communication at a logical level, it was probably responsible for the QSOUND signals reaching the end correctly, and, for my surprise, it worked. The sound was perfect.
I tested another game, ZERO 3, also perfect.
I left testing a few more hours and playing at the same time, but the sound died on me.
We will investigate again.
I was sure it was not QSOUND, as ZERO 3 does not start INTRO if it is not communicating well, and neither does JUKEBOX, and both were perfect.
I think that this board was lay aside for years and suffered a lot of degradation, even more with the giant battery leaking, maybe the most sensitive ICs were not withstanding the current flowing, and also the sound impedance, so I started for the LS374 next to the last replaced LS245. With the 4S LS374 it didn't work, but when replacing the 3S LS374, the sound came back more beautiful than ever.
Until then, the sound was from JAMMA, in mono, I went to test the stereo, nothing.
By the diagrams, I saw that the sound signal leaves the QSOUND and passes through the 6P F04, goes to another logic IC, until it reaches the 10J TDA 1543, which receives the signal and directs the R and L signals to the LM833, until it reaches the 10E TC9176P, which will send the signal to the amplifier and then to the outputs. I checked the continuity, it was ok.
Then I changed the line ICs one by one, when I arrived at the TDA1543, the stereo sound was magnificent!
It was already a day in testing and the card was working correctly, so I decided to switch to another game, this time X-men vs Street Fighter, and, sadly, again graphic problems, and this time very strange. As you can see in the video, after inserting credits, the game normalized (???)
I did not want to replace the DL-0921, as I was “almost sure” that it was not him, since I did some tests with instrumentation on all pins and did not present wrong comparative values, so it could only be some CI still defective or bad traces.
I went back to studying the documentation. There are 5 pins responsible for the management of BUS address, my intuition said that that was it.
In a continuity test between these pins with signals that come out from DL-0921 and go to CN1, I identified that the signal from pin 81 was not reaching the socket pin. Following the trace, I found the culprit.
Repair done.
Game working like new \ o /
In addition to the help of the documentation already mentioned, I also used a semi-decapped board for continuity comparison.
It was a few days of work on this board, hours of study, but a lifelong learning experience. I am very satisfied, since until then, I had never had many results on A boards with these kind of problems (mainly sound), simply abandoned the service or if it was mine, sent it to the scrap box.
Sorry for the long text, but I hope it can help and encourage the community to not let their PCBs die.
Any problems, doubts, suggestions or criticisms, get in touch.
This is great! I love reading detailed repair logs with nice photos.
Thanks friend. I forget some videos with the bad audio, but i tried to describe in words what was happening. On my next article i will try to remember.
What is the correct value / part for replacing that supercap?
Mine has the labeling turned to an unreadable position. I can see it says 5.5v but not the rest of it.
Also is there any general advantage to replacing the big 1000uf capacitor?
This is amazing mate! Mad props to your soldering and troubleshooting skills
I have one question to ask as I have a "rebooting" issue on my CPS2 A https://www.arcade-projects.com/forums/index.php?threads/cps2-a-board-freezing-crashing.12179/, you stated the following:
Are you able to provide which capacitors exactly you changed? I'm assuming the large capacitor you're referring to is the one labelled CC1?
If my "issue" is simply a couple of caps, I'd be more than happy to try it replacing them and seeing if it resolves my issue.
Thanks
Thanks
It's really random. My problem was with some caps, but if there's any damaged or bad soldering IC, you will get reboots too.
Yes, the little CCX caps on that A board was tantalum, but normaly i see electrolytic.
Fantastic writeup, wish I had it back when I had a couple of A-boards that seemed completely functional except for sound (no audio, and volume controls "non-functional" [switches were fine]). I replaced a ton of parts but never worked it out, wonder if this would have helped :)
In the past few weeks I have continued to study the A Board documentation and did several tests.
There are many types of defects that can happen in these boards, but we will always “attack” the most frequent, and one of these is the problem of NO SIGNAL/DEAD board. With the help of the documentation we have more hopes for restoration, but seeking help is also important, so I talked with @l_oliveira and @WydD to find out how the CUSTOM’s system works and I was able to understand a little more about the cause of the problems. Thanks guys.
What I did: I picked up a working A board and took off each CUSTOM, leaving only the DL-0921 untouchable, since it is the synchronism generator, just to know the limit that the board would remain active. In the end, I realized that this is the limit. In red are the ICs that work on the sync operation.
The H and Vsync signals come out of DL-0921 and work together with DL-0311 till it out as Csync on JAMMA.
With that information in mind, I was ready to analyze the RESET circuit:
I did a lot of tests, and, summarizing, when I have a NO SIGNAL/ DEAD board in hands, first, I do apply, as method, is just remove one of the logic ICs from the RESET circuit line. I usually choose the "11K LS07".
What happens is, when any component is took off from the RESET line, the signal that leaves from M51953B is lost, so the system will lose the automated control and the synchronism will appear (it won't happen if any IC is blown), and that's all I want at the moment.
I typically use an Extron RGB to check for a sync signal.
Knowing that the synchronism works, it is necessary to check which component is blown in the RESET circuit. Check them all, replacing one at a time and some possible damaged trace(s).
The most recent A board that I was restoring presented a combination of all the errors already mentioned in the first post plus some that I had not yet witnessed.
First, the board had no sign of life.
This time I realized that the "13K LS04" was kind of weird physically, I removed it, the sync appeared. I replaced by a new one and the circuit was perfect again.
When connecting A+B boards, it shows static garbage, without any movement on the screen or sound.
I replaced the 3 LS245 (11P / R / S) below the DL-0311, since they work with the program code coming from B board.
On a new test, the game came to life, still with graphics problems and without sound.
After replacing all the LS157 (2T-W / 3T-W and 7U-W) that is around the DL-0921, plus some corrections of damaged traces, the graphics came back to life, but still with errors.
After some searching, I realized that a signal from the DL-1625 (pin 61) near the memory (13V) was not showing continuity, it was one of the traces that was damaged.
Now the graphics are perfect.
Let's go to the sound.
I did the basics, which was to clean the volume switches, and check if the signal was reaching the sound circuit, and showed that one of these did not.
After the trace corrected, I soldered a supercap that was depopulated don't ask me why. I also changed the data reception logics for the QSOUND (LS374 around the DL-1425) and the sound was perfect.
I just loved this cubic supercap!
With the job done, I cleaned the board and that's it.
This past week I managed fix some A boards, thanks God.
But there’s still many waiting.
Please share if you know more about A boards.
Any correction, criticism or suggestion, please enter in contact.
Is it version 1 or the champion edition version 2 of the multi?
If version 1, are your jumpers correctly configured and do you have the proper Pal G chip?
Thanks for the reply @mR_CaESaR
I have version one (bought last June). It seems the jumpers do not need to be set any longer (I initially followed the guide and started to connect the jumpers, but stopped once I found out not to set them any longer and then undid the soldering I had done).
I put in the PAL chip that came with the dark soft kit, lifted pin 9, soldered a wire to it and then connected it to the J17 pin on the dark soft board.
I have various pics here I took:
https://drive.google.com/drive/folders/1-7Hwx_RXSz_3N8JOcMX7AE7jz2YiC0wq
I thought it was only version 2 that you don't set it for.
For my multi, I set it like this as I too had that garbled sound prior to setting up the jumpers
SOOS SO OSOSOS SOSOSOSO SOSOSOSO (S = short, O = open)
If you no longer need it to be set - then I stand corrected :)
My Japanese A-Board have a sound vanishing issue, while the video signal is perfect.
Any clue to fix it ?
