Hello I am finally starting my 2 Aero City project cabs.
List of what needs to be done.
Get cp harness's
Get rid of rust with Krud remover
Repair cp outer housing as its a rust fest.
Drill locks out
Fix wiring
Patch lock holes
Grind off security lock guard
leave paint as is or repaint cabs. ( havent Decided @hoagtech was helping me look for options)
Buy new graphics if painted
Buy ls-32 sticks and new buttons
Fix glass bezel artwork.
Cabinet 1
After moving one cab in I was able to turn it on after fixing the rats nest and removing soe redundant wiring. But it had no sound and the picture was great. The screen had some roll over on top and picture was a little dark. I could not adjust it as locks had no keys. I am not sure if i can adjust it out till i can try or it requires a recap
After my friend came over today to drill out locks on Aero we found out that the wiring near speakers had 2 wires cuts which would be the reason the sound wasnt working. He took that wiring to his work to solder for me.
I have a whole psu on wooden block coming from buyee to change out if need be.
Voltages where ok on the 12v but the 5v was a little low but cames worked.
the glass artwork was ruined or flaking from the foam that rots
Rust on inside bottom of cabinet
Cabinet 2
Its not nearly as bad as the first cab but the wiring is complete and in tacked.
No lock guards or holes except on coin door weere there is a added on plate i can take off and fix with epoxy and paint.
Have not turned on machine yet
Glass has same flaking and problem from melted foam.
Get cp harness's
Fix wiring
Patch lock holes
Cabinet 1
Cabinet 2
