Clownkicker
Hello, I'm definitely a beginner so please bear with me.
I've had this Street Fighter Zero 2 Alpha CPS-2 B Board from JPN for a while now. It currently just sits at a black screen when I power on. No sounds can be heard, just a black/grey screen.
Some facts about it:
Things I've tried so far:
I still suspect a bad connection between the A and B boards, given the general flakiness even when it was working. What is the best way to verify that connection when the board is on?
Thanks in advance for any help!
- It WAS working for me previously, although it's always been a little flakey. Sometimes I've had to push down on the board to get it to start. Now it won't start no matter how hard I push down or re-seat the connection between the two boards. I am using the clips to hold the boards together.
- I did install an infinikey at one point. It WAS working with it installed (and the battery removed).
- I've tested it on two different CPS-2 A boards. It works on neither. Both A boards work successfully with other games (X-Men-vs-SF and AvP).
- General cleaning of the board. Current state can be seen here: https://imgur.com/a/uLQEtJS
- Tried to clean the the A-board connectors by spraying DeOxit in there and letting it dry upside down.
- Generally inspected the board for broken traces, etc. Nothing was obvious to me.
- Reflowed the solder connections on the infinikey, just in case.
- Pulled all of the EPROMS, 01A through 08A (I believe these are all of the prog chips), cleaned the pins, reinserted them.
- Checked EPROMS 01A through 08A with a TL866, compared them against the SFZ2ALJ mame set. All chips came up 'successful'.
