I have purchased a Capcom 3 PCB set of Commando and it has a mix of PCB separators, currently plastic or whatever the material is, that do not hold the lower board to the top 2 boards I am assuming this is not correct considering that these were mounted in Cabs. My question is if I purchase some Hex standoff spacers to fasten these PCB together is it safe to use brass or should I use the plastic/nylon type? I want to make this assembly sturdy so that it can be safely set on a table top for use with a Supergun. The few that are on here are ruffly spacing at about 17.6mm so figure 18mm would be fine or should I error on the 17mm side?
Also what Capcom system or category does this PCB set fall under? I am extremely new to this hobby and want to learn as much as possible about the different architectures of the many brands of arcade systems. I did some searching on the interwebs but am still a bit confused at what this set fall under.
Thanks for any input or help y'all can give.
VWI
VWI
