Hello everyone,
I have 3 questions to clarify concerning the GPAL FPAL and jumper configuration
I have a REV. 7 B board, X VS SF with a FPAL chip ,was already suicided(through passage of time) when I got it.
1. In the Darksoft prep vid on youtube, the recommended easy PAL configuration is the GPAL. Can I remove the FPAL on my board and install a GPAL from highscoresave.com?
2. I read a comment on the vid, "If you have a F pal and a Rev 5+ board, just pull out Pin 7 and jumper to Pin 9 no need to run a jumper to Cn3-C13"
Just to confirm the PIN 9 is located on the FPAL and do you have to pull out the pin 9 like the pin 7?
3. The Darksoft installation pdf file version 3.2 says to leave the jumpers as is(no soldering),but the video says its needs to be in the certain open closed configuration, My board needs 2 points soldered to match the recommended configuration.
Should I leave it as is or solder the points to match the configuration?
Thanks so much in advance for answering my questions,I really want to take the Darksoft leap, and I really dont want to sacrifice my 3 other boards(GIGAWING,SFA3,HSF2 especially my HSF2 board!)
