pacoarcade
Spain
Shipping to EU via Mondial Relay or courier.
Key features
  • Low voltage drop with 2x4 sturdy gold-plated power connector
  • Galvanic isolated audio with subsonic filter
  • Made with high quality components
  • Regulable R-G-B + brightness via one knob
  • Standard pinouts (XRGB-Mini, Undamned)
  • Safe buffered CSYNC output for 75Ω or TTL CSYNC
  • Attenuated audio or direct speakers output
The supergun comes with the PSU cable (with gold plated pins) but it doesn't include AV cable. There are manufacturers of this cable since its pinout is used in other devices, or you can build a MiniDIN8 to SCART adapter and use a MiniDin8-MiniDin8 pin to pin cable:
http://etim.net.au/cable-adapter/scart-guide/
https://oshpark.com/shared_projects/E08Jw50C
https://www.arcade-projects.com/threads/mini-din-8-to-scart-adapter.10970/
  • pacogun24.pdf
Through DB15 connectors (Undamned pinout) or through Service button at the left.
-- Edit: Version 2.4 has a COIN1 button onboard.
I see but service button doesn't work for all games.
What is undamned pinout? Those DB15 connectors usually follow the NeoGeo pinout, can you use MVS with your supergun (at least the JAMMA 1 slots)?
It works with MVS but this Supergun doesn't support Stereo sound. With my MV2 I set the switch to SPK and take the audio using a minijack cable directly from the Neogeo using a MD8-MD8 with one of these adapters:
SPK / LINE switch selects to output sound through the molex connector or enables the attenuation circuit to get output through MD8 / Minijack output. So selecting SPK the audio is not processed. There is also a footprint to take SPK+, GND, SPK-, GND to connect stereo speakers for MVS.
This is the Undamned DB15 pinout, the same used by the Minigun. I use it with Arthrimus Saturn to DB15 controller.
1GND
2Button 6
3Coin
4Button 4
5Button 2
6Right
7Down
8+5V
9-
10Button 5
11Start
12Button 3
13Button 1
14Left
15Up
I bought HSS-0101 from Japan at eBay some time ago, but you can buy brand new controllers too. In Arthrimus Saturn to DB15 Controller Adapter page he specifies other compatible controllers.
You need the Arthrimus adapter in order to use Sega Saturn controllers with this supergun, but you can make your own (I used this extension cable to get a compatible connector):
SEGA Saturn to Neo-Geo controller adapters
https://oshpark.com/shared_projects/yE8DCMIC
Since it's MVS extended pinout it should work with Neo-Geo controllers but I've not tested this. Since it follows Undamned pinout it works with every adapter that follows this standard.
Great supergun with good ideas, great support !
Don’t hesitate, very good stuff !
thanks :thumbsup:
I got that gold-plated pacogun - this is a quality product with great performance , can't recommend it enough!
coming from a bs cheapo supergun this seems like a monumental upgrade to me and pacoarcade is more than helpful !
I had no questions about pacogun since it just works but everything else I asked about psus etc all were replied promptly!
thanks!!!!!
A great supergun with very very high quality components !
i'm using SUZO HAPP POWER Pro LT-200W with custom power adapter, working fine !
Waiting for the next version ! Do you have some date for planning production ? :)
Thanks
Nicolas
I have a Pacogun 2.4.1 for sale in the EU.
More information in the first post.
Nic034: sorry, I must have deleted the reply I put here; for now I don't plan to release new versions since it works fine as is.
