I bought an original M$ Xbox360 wired controller (the Battleforce 4 special one). It is recognised by the Lindbergh (plugged into a USB socket on the Lindbergh) but doesn't work. Precisely which versions of the original Xbox360 controller work with the multi 9.6 setup (I realise clone non-MS controllers don't)? Does it have to be wireless controller, and if so exactly which versions?
Thanks!
Edit: Bit of background. The Lindbergh is plugged into a Net City with JVS I/O in the cab, not in the Lindbergh cab. Does this setup work with an Xbox360 controller or do you need another I/O board like the S-JIHP: Sega JVS I/O Helper PCB?
Thanks!
