Midway Wolf conversions
    • stj wrote:
      btw, that datasheet clears up your other question.
      the crystal is 32.768KHz
      calendar crystal... Neo MVS boards use the same type
      stj wrote:
      how so?
      if the game is writing data to a non-existant cmos ram - it's not the games fault!
      Could be a anti conversion measure? The game still runs if an op converts it but not properly so they contact Williams/Midway and get told to buy the board instead of trying to convert one? Either that or for whatever reason NBA Hangtime uses the calendar for something, maybe specific unlocks? Character X can't be unlocked unless it's a certain date/past a certain date?
    • Hello everyone!
      Earlier in the thread there was a post for the "Any U64" romsets. Those were created by me!
      Thanks yavuzg for the concise feedback with photos on the rom hacks and potential problems.
      I patched the start up test screen to display 'ANY-U64' in place of the Game ID so collectors would know it was a conversion. I also RE'd the checksum routine and wrote an app to calc/write new checksum bytes so checksum works and isn't patched out/bypassed.
      Darksoft - the level 2 security check was another check later on in the code that looks for the game id. I missed it too when first patching :) The id check is the same if you search the disasm for same code
      Credit problems - I haven't had that happen myself, perhaps cmos needs to be reset (book keeping issue?)
      Start up without PIC -- the PIC has several functions that it provides to the Wolf unit pcb, so it is needed
    • Source Code
      1. MK3 V3.21:
      2. FFB0A770: 42 0B EF FD CMPI 210h,A2 ; check calculated value (528)
      3. FFB0A790: 05 CA JREQ FFB0A7F0h ; jump if equal
      4. FFB0A7A0: 42 0B 48 FE CMPI 1B7h,A2 ; check calculated value (439)
      5. FFB0A7C0: 02 CA JREQ FFB0A7F0h ; jump if equal
      6. FFB0A7D0: 00 C0 FE FF JR FFB0A7D0h ; endless loop - stop code execution
      7. NBA HANGTIME:
      8. FFAEFBD0: 42 0B EF FD CMPI 210h,A2 ; check calculated value (528)
      9. FFAEFBF0: 17 CA JREQ FFAEFD70h ; jump if equal
      10. FFAEFC00: 42 0B 34 FE CMPI 1CBh,A2 ; check calculated value (459)
      11. FFAEFC20: 14 CA JREQ FFAEFD70h ; endless loop - stop code execution
      Display All
      From my notes, here are two examples of how the check works. The value being compared here (shown in decimal, in brackets), are the first three digits of the serial number labeled on the U64 PIC.
      But what I wanted to show is there are two checks in every Wolf unit game. It always looks for 528, then a unique value for each game. The serial prefix 528 was perhaps a 'developer id' used internally, so they had a single PIC for booting any game
      I can confirm it is possible to create a PIC that returns an encoded serial number starting with 528 :D
    • A wise person point out to me recently how few people within the community actually have the skills to circumvent the various forms of protection used in these games over the years.
      Welcome brizzo, and yes please share all that sexy info! :D
      Darksoft: CPS3, CPS2, F3, MVS
      RGB: RECO v2, HAS v3
      invzim: Jammafier v1.6b
    • yavuzg wrote:
      Darksoft wrote:
      The only way to know for sure is installing those missing components I guess.
      Just ordered some MK41T56N from aliex. I'll let you know the outcome...
      Installed it, along with the RTC crystal. Nothing changed. Same errors. Installing it has absolutely no positive or negative effect.
      Either;
      a) Additional components needed.
      b) The MK41T56N from aliex is a dud
    • Having fun ...
      Blank checking... Code Buffer
      Elapsed time: 0.91 seconds.
      Device blank check failed at address: 0x00007E, Read= 0x7F.
      Blank check failed
      Elapsed time: 9.05 seconds.
      Device blank check failed at address: 0x010002, Read= 0xFE.
      Blank check failed
      Device blank check failed at address: 0x0000CE, Read= 0x7F.
      Blank check failed
      Elapsed time: 114.85 seconds.
      Device blank check failed at address: 0x0E0B06, Read= 0xFE.
      Blank check failed
      Elapsed time: 2.95 seconds.
      Device blank check failed at address: 0x00498B, Read= 0xFB.
      Blank check failed
      at least some work but man ... lots of roms of that stuff!!
      hopefully the third erase will work!
    • Wow, I guess I should have read through all the forums. I had this wolf unit multi idea years ago , now it looks like people are all over it.
      Brizzo just FYI, the PIC chip codes are all almost identical except in three different places, I'm assuming the PIC serial number with the first three digits is what is needed which is why I started a thread a long while back with all the PIC serials I could find. I can probably change a PIC to the 528 that you mentioned as well (I have most of the PIC codes).
      I think the only way to do a multi Wolf PCB is to be able to make a PCB that plugs into all the sockets on the board and then feeds the sockets with correct rom for each game from a SD card . The security is already removed so its basically a hardware game at this point. Its crazy expensive to buy the 8mb eproms these days and most of the games use the 801s. Hell with the speeds raspberry pis are running at, you could probably just build a WolfPi setup with jamma adapter running some sort of mame.
