Hey undamned!
I finally got my setup going recently: a CPS2 copy of VSAV, a Windy supergun, and two UD-USB decoders. Two sticks I have are a Hori RAP4 and a 360 TES+.
So far, so good.
But once I finally got everything in place, I was having an issue, and I think it was this same one as this:
@Niko &
@tom5151, I think I know what's wrong w/ the signal that is stuck on always. Fix should be a simple firmware update. Basically in the last hardware revision, I made provision for future use of Pin 9 (whereas in previous versions it is not connected at all). My guess is that my firmware is always asserting that signal, since I'm not intentionally controlling it yet. I'll try to get that change made this weekend and post up. Sorry for the booboo. I'll detail later why I connected it in the first place
In my case, the LK input was always listed in tests and in-game as held down, even when there was no controller connected, as long as the UD-USB was plugged in.
Remapping the buttons didn't solve it, as it seemed to be the input rather than the button.
So I did some searching, and found this thread and the beta firmware:
I did actually! See if this version fixes your (also paging
@Niko) problem:
https://drive.google.com/open?id=1Zv3ZUzdVaRRMRKJWnjxqjBSR7wH3ywqZ
So I updated to 1.4b and tested it today. And I'm still having the issue, but a bit different.
Now, the LK input is permanently 0 instead of 1, with the same problem that rebinding doesn't work to get around it.
Both sides, both decoders, both sticks.
I'd appreciate any help you could offer, would love to get this going
