Hey Guys,
Ok, got another issue I've been trying to get sorted but haven't had a lot of luck so far.
I have a Battle Gear 2 (twin) driving cabinet where the hdd had failed on one side. both sides fully functioning otherwise. I have made an image of the working hdd and sent it to AndyGeezer who has developed a script to replace the security reference that checks the hdd serial number.He has been sending me a modified seed file that I've been writing into the original image, then cloning onto the new hdd, even tried new ssd's and an IDE-SATA adapter. However after multiple attempts with multiple drives I can't seem to get it to work. So I'm wondering if anyone has had any experience with this or knows of a dump that has had the security removed that works on the original Type Zero Hardware?
I have been using WinHex for the cloning and editing process.
Also it should be noted that during this process my son bumped the working hdd off the bench and killed it. So I now have no working drives, just a raw dump of the original drive. Nothing worse than having cabs you cant use.
