OldSchoolNeo
I purchased a Naomi 2 setup complete with Net Dimm and Raspberry Pi with a touch screen on ebay that came loaded with pretty much every Naomi and Atomiswave game out there. It came with no instructions so I watched a video from Jansens Customs on YouTube and was able to write a game to the Net Dimm and it played without issue. So I know my setup initially works although I was a bit confused on how to write the game to the Dimm.
The problem is it is setup to use a Ada Fruit touch screen which I'm not familiar with (came with no instructions). The screen has scrolling arrows on the right and left to cycle through the games on SD card and a third "sprocket" looking icon in the bottom/middle portion of the display. It has four physical buttons on the side that are simply labeled with numbers. The first time I used it, I simply guessed that the "sprocket icon" was the equivalent of the "Select" button on the non touch screen Pi setups. I touched it and it went through the writing process, restarted, etc. It worked, I played the game and thought "this is freaking awesome"!
My problem is I went to load another game and somehow in the process it deleted the currently loaded game and will not load a new one. Hitting the sprocket icon does nothing, the arcade monitor is simply stuck on the Error 31 message.
Here's my setup: Naomi 2 with Net Dimm in a Sega New Net City cabinet. I have the cross cable connected from the Pi to the Dimm, my Dimm is 4.01 per the Dimm Tests. When I power up, I get the "Checking Network" message so I go into the test screen and set the IP address (192.168.1.2 and 255.255.255.0) save the settings and exit. The Naomi reboots but I get a Error 31 as there is no game written to the Dimm.
The Pi is using an infernal touch LCD which looks nice, but it does not have any buttons labeled to test the connectivity between the Pi and the Dimm nor do I see a physical "Select" button to send the game from the Pi to the Dimm. I would have much rather have had a "basic" Pi plate setup. So basically the Error 31 is legit as there is no game loaded. All the videos I see online are for the older Ada Fruit Pi Plate setups, so I have no idea how this thing works.
The Dimm appears to be fine, the crossover cable works (I connected the Pi to my laptop and it recognized it) and it worked the first time. This is extremely frustrating.
Any help or advice would be greatly appreciated.
Thanks!
Thanks!
