Hatsune Mike
Source on Github: https://github.com/Mikejmoffitt/hyper-fighting-cps2
Credit to trap15 for EEPROM sample code and some work with the CPS1->CPS2 priority encoding.
If you want to donate (absolutely not required) you may use PayPal here.
Current progress:
Features / Completed Tasks:
* Player 1 & 2 joystick and button reading
* Kick harness reading and format conversion
* System switches conversion (coins, starts, test switch, service)
* CPS2 QSound ID translation
* Hyper SF2 sound driver (maintain original CPS1 sound effects where possible)
* CPS2 sprite hardware utilization
* Sprite table update with correct drawing order and termination (no need to clear the table every frame)
* Multiple levels of speed adjustment (like console ports!) with the default being more or less the original speed
* Configuration for soft-DIP settings stored in EEPROM like a normal CPS2 game
Feature adds I'd like:
* Allow winning player to change characters in versus matches
* Allow stage selection / rotation of stage choice so you aren't stuck listening to the elephants on Dhalsim's stage forever* I would like to replace the instrument samples to better resemble their CPS1 counterparts
Remaining bugs:
* "Burning oil drums" bonus missing the top drum unless screen scrolls up (likely a sign extension issue for Y position)
* Screwy "A New Challenger" text when the second player joins
Likely not going to be fixed:
* Endings have some flicker; some endings (Ken's ending) use per-color sprite priority encoding which is a hassle to fix
* On the fastest turbo speed setting, sometimes HUD sprites flicker for a frame on occasion
* Between screen fades for a frame or two sprites are visible on-screen when it should be a black screen
Closed Issues:
* I must finish the DIP configuration screen
* Game runs very slightly too fast compared to original SF2HF board
* High score table and end-of-match text does not show up (need to trigger a sprite update; normal function isn't used here)
* A few sound effects are mapped wrong (Dhalsim's flame hit sound, Dictator's psycho crusher attack sound)
*Strange palette issues on hardware ( seems like an offset in the palette source address? See how I picked green guile but got blue guile in-game? ) Took sprite list update routine out of vblank, no longer ruins palette transfer timing
* Minor sprite/background layering issues (life bars on Ryu stage, Title "turbo" text Fixed
* Minor sprite flicker for some text in-game, and in the punching intro Resolved alongside palette issues
* Background updates must be synchronized properly with sprite updates (off by one frame right now) Fixed alongside palette issues
Current progress:
Remaining bugs:
Closed Issues:
