Hatsune Mike
Release put in OP, but here it is too: http://mikejmoffitt.com/bin/sf2hfjcps2.zip
Great work Mike. Completely forgot that you were working on this one.Release put in OP, but here it is too: http://mikejmoffitt.com/bin/sf2hfjcps2.zip
I'd love to see CPS1-> CPS2 conversions. It's a lot of work thouhg. From graphics and code side is the same as CPS 1.5 -> CPS2 AFAIK. Then the sound should probably be doable. But please let's not overdose this with propositions. Let's leave the experts work on CPS 1.5 -> CPS2 and we'll take it from there. Once that's been mastered, convert the CPS1 games should be much easier IMHO as only sounds will be left to convert.This is so awesome!
More CPS1 games on this the better IMO.
I personally would love to see 1941: Counter Attack running on this. That’s another CPS1 game that isnt widely available to play via ports (unless you have a Supergrafx)
Does this happen reliably? I've had this happen once or twice, but I've gone in there probably almost a hundred times by now. The EEPROM code is the last thing I did, and it's definitely not as verified as everything else.This conversion is great, thank you for the hard work you've put into this.
One minor issue I noticed is the game crashed when I went to test mode on real hardware w/ the CPS2 multi. Doesn't really matter though, your default settings are perfect.![]()
Actually other than the music the sound effects are the correct CPS1 ones, re-used from Hyper SF2 Anniversary.It plays beautifully and I love the JAP intro with the word 'Turbo'![]()
I wish I knew how to do what you guys do!
Im guessing the CPS1 sound effects etc are an impossibility to use on CPS2, but u know what, still extremely enjoyable all the same!
Amazing work, thank you so much
Nope I haven't had it happen again so far, just the first time I went into test mode to try it out.Does this happen reliably? I've had this happen once or twice, but I've gone in there probably almost a hundred times by now. The EEPROM code is the last thing I did, and it's definitely not as verified as everything else.This conversion is great, thank you for the hard work you've put into this.
please provide always as much information as possible, if you want to get it solved. Are you using a version ready to use with the CPS2 Kit? Do you see the name of the conversion on the LCD Display? what happens when you hit OK in the LCD? Starts writing? How long before the error shows up?what am I doing wrong?
