dr_myslihiiri
I bought a Japanese Mars Matrix CPS2 B board a while back, and when I first got it, it worked without an issue. When I fished it out of storage yesterday and plugged in again, it began exhibiting visual glitches, including vertical lines running down the screen and corrupted text.
Reseating the B board did not immediately fix the problem, but nudging it a little did. I guess this is down to a connector not making proper contact with the A board. At first blush, I couldn't tell if any of the pins were bent.
Does anyone happen to know which particular connector is responsible for passing down the graphics signals, so I can have a second look? Is there anything else I should check?
