Something is wrong with the simms or your cart is dirty. If it is a superbios cart hold 1 player start while you boot and then select flash memory in the darksoft menu. You will then see the faulty simm.
I want to add six 16M flash chips to the 32M simm board to turn it to 128M simm, also i noticed that there are MLCCs in vicinity of each 16M flash chip, do i need to solder it on and what's the specifications of the MLCC?thanks
Every other game runs with no problem, only JoJo's Bizarre Adventure has the problem. Cleaned SIMMs, testing again now. Only thing I haven't really done is swap over the good working set of SIMMS
Alright CPS3 still at the same problem. We've swapped all SIMMs, cart, cables, SCSI2SD, SD card, so it's definitely something with the motherboard. We've tried all regions, and free play. Why would every game work 100% except JoJo's?
I'm pretty much just going to list it for sale as it is. I need to make the return on the parts, and I can't afford to put it off any longer.
