Geddon
USA
I searched but am surprised I didn’t see an answer. Is cn24 line level? I want to get stereo sound to rca jacks ideally.
The service manual calls it ‘audio line output’ so I assume it is line level?
Yeah I think it is. I did a quick test. One channel seemed quite a bit louder than the other. I’m going to run the 4 pin to 2 rca female connectors. That goes to a mixer then to my speakers so I can adjust the lower channel if I need to.
be careful not to invert the cable pinout, I made the mistake once and the heatsink was burning hot
Sorry for the necro bump I’m having the same problem, so hot it’s untouchable 🥵 which cables need swapping round?
I’m using it with a small sanwa stereo amp in an egret 3 cab, luckily i checked the heat sink before I put the pcb away in the cab think it would of melted lol.
