Sega Model 2/3 A/B/C - CRX and how I stopped worrying and learned to love the bomb.
    • Sega Model 2/3 A/B/C - CRX and how I stopped worrying and learned to love the bomb.
      media][/media]
      Look at this thing! Look at it's glorious games!
      How in the hell do I wire one of these up?
      Well that's why I started this thread... I'm a n00b and wanna learn. Lets learn together.
      I bought a Model 2B CRX and know nothing about it outside of that it looks like it's a thicc stacked juicy burger of sexy PCBs from SEGA .
      These metal burger bath-tubs always intrigued me, and to say the least within a year or so, I'd love to assemble my own Model 2/3 SEGA multi driving setup, or perhaps collect a couple unreleased titles.
      It didn't occur to me how complex these seem to be, and can be quite imposing when you unpack it and go WTF.
      I hope you're a glutton for punishment...
      s
      What do I do now?!?!?!
      With that said I'm moving my information thought dump here so I can ping you good folks for help.
      Now as it stands there's multiple ways of connecting this thing up.
      (Yes I know there's other sub threads in other places, but this is now in one place)
      Edit
      Don't make me hit a bitch with a Blast City!!!
      What are my options??? Jamma? JVS??? Japanese Harnesses???? LOLWUT?!?!
      Blast city harness... I have a Blast City Cabinet.
      page.auctions.yahoo.co.jp/jp/auction/k374885579
      "I've never understood why wire is so expensive." @twistedsymphony
      part number 600-6738-20
      I'm not sure if model 2 got it's own loom, but they're nearly identical
      the top section plugs into your board, and the bottom section plugs into the Blast's IO board,
      Then I saw this thing from Hong Kong...
      ebay.com/itm/Sega-Harness-Mode…Board-28-Pin/182049587191
      Interesting and I'm sure it'll work with most units.
      Also, here's a nice compendium of VOLTAGE Differences and Notes:
      The biggest difference is that Model 3 requires 3.3V power (similar to newer JVS boards) while Model 2 only uses 5V so the power supply will need to be upgraded to a model that provides a 3.3V power source.
      There are really 2 connections that need to be changed when going Model 2->Model 3.
      1. The Main Power Connector:
      Model 2 has 3 10-pin connectors for 5V power, 5 pins for 5V, 5 pins for ground on each of these (CN1, CN3 and CN12 on M2A and CN9, CN10, and CN11 on M2B/M2C).
      Model 3 uses one of these 10-pin connectors for 5V power (CN14) and also has a large 24 pin connector (CN13) that includes 8 3.3V lines, 6 5V lines and the rest of the pins are ground. you could re-pin one of the 5V connectors from model 2 to populate half of this connector and then fill out the rest of it with fresh lines for 3.3V. In my case I'm leaving the two extra 5V connectors from Model 2 disconnected and simply adding a whole new connector for the 3.3V/5V connectors that Model 3 requires so that I can easily swap back to Model 2 if I so choose.
      2. The Fan Connector:
      Model 2 has an externally mounted 12V case fan that uses a 2-pin Molex connector going directly to the fan (not in the diagram), Model 3 has 2 internally mounted 12V case fans that receive their power through a 3-pin JST NH connector on the filter board (CN16). For this I made a simple adapter cable with a 3-pin NH connector on one end and a Molex connector on the other end. This makes it plug and play, and keeps me from having to run new 12V wires while reducing the number of unused connectors.
      *A Note about the 5V output connectors
      Model 2B/2C and Model 3 all use the same 11-pin connector for 5V output (the additional pin makes it easy to tell apart from the 10-pin input connector). Model 2A has a 11-pin 5V output connector too, however Model 2A also has an additional 9-pin 5V output connector. that the later boards are lacking. This seems to be the biggest compatibility difference between Model 2A and 2B/2C.
      All other connectors should be pin-compatible.
      I will say that the audio connectors were listed has being pinned differently in nearly ever manual I cam across, even the audio connector on one of my Model 2 boards (just one) was plugged in backwards, which I confirmed by metering out the ground pins. so I'm least confident in that connector (though worst case is they L and R are swapped or it's out of phase).
      Most pinouts for the 25-pin digital control connector that I found online were wrong when compared against the service manuals and against my own machine wiring. so it would be nice to get confirmation on that connector from another working setup.
      EDIT 11062019: Stolen from a recent post from TS... Appending to this thread.
      SUPERGUN Model 2????
      Concerning powering a VF2 Model 2 to a Supergun.
      Proper voltage wasn't allowing the unit to boot.
      This is the fix.
      you take the ATX connector pinout:
      To force the ATX PSU on you need to hook "PS_ON#" to any of the "COM" (AKA Ground) pins.
      then you run the rest of the wires to the correct pins on the model 2 board power connectors:
      the hard part is the fact that there are only 5 +5V pins on the ATX connector and there are 15 +5V input pins on the Model 2 filter board. The filter board uses JST NH connectors which only support up to 22awg wire I believe. so what you'll want to do is crimp 2 22awg wires together on each 5V pin of the atx connector so that you have enough to fully populate the model 2 connectors. and then start tapping +5V pins on other connectors on the power supply, if there are CPU and GPU power connectors use those and failing that you can start using the 4-pin "molex" connectors.
      Footnotes:
      I got a lot to put here, but if you have anything else of use, go ahead and toss it in.
      I can't seem to source manuals or wiring diagrams for most of this stuff.
      Thank you for @twistedsymphony for piquing my interest in kicking the tires on one of these.
      Join PM1Arcade Discord
      Bench : NAM75 Repair| CPS1 SF2Turbo Conversion
      WANT : EPROMs, Taito F2 Rom Boards
      [astrocity] InstaGram [neogeo] Arcade Projects Photoblog [saturn] VAPS List [nes-101] Tuesday Arcade Twitch Stream!
      The post was edited 1 time, last by psykom1 ().
    • Well you've got an information dump for the Model 2 side of things... but here's what you need to know about the Blast City Side of things:
      wiki.arcadeotaku.com/w/Sega_Bl…Guide#Cabinet_I.2FO_board
      basically you just need that, my model 2 diagram, the parts and some time
      Projects: instagram | blog
      Wanted | For Sale/Trade
    • it looks like you have a Model 2C PCB so all you really need is this pintout:
      and then match all of the pins to the pinout here: wiki.arcadeotaku.com/w/Sega_Bl…Guide#Cabinet_I.2FO_board
      the rest of the information in your "dump" is just noise.
      Well, I'm far from done, but i'll be using this space to mess with.
      With concern to trying to also build a harness for a supergun, all of this will prove useful.
      Thank you for the help and pointing the way.
    • I guess this confirms that Virtual fighter 3, the first model 3 game, does not use midi :
      oh seeing that the JST-RA connector is out of stock, if found at all, anywhere, I just found that a good old ribbon cable floppy connector actually is the perfect fit on CN5 of a blast city.
    • This is gangster, but it works.
      Lord knows I've harvested a floppy cable or two in the last year.
      Enjoy that VF3.
      I wonder how much better it looks over the Dreamcast.
      The last time I played VF3, it was at the Luxor in Vegas right after I turned 21.
      They had this monster large projection screen cabinet.
      Enjoy that shit.
      VF3 is a killer game, and one of the best in the series next to part 2.
      The later releases 4 on just don't do it for me.
    • psykom1 wrote:
      Enjoy that VF3.
      technically the Dreamcast is a higher performance system than Model 3.
      If you look at Virtual On OT on the Model 3 hardware, versus the version that was later released on Dreamcast and NAOMI the DC/NAOMI version is higher resolution with higher res textures and some nice Anti Aliasing but has worse particle and lighting effects. this is because the Model 3 had some particle and lighting features that the DC hardware lacked, so they just cut them out when porting the game. It's entirely possible they did this with VF3 also... it's also possible that with VF being a flagship franchise for Sega they took the time to make use of the other advanced features the DC offers.
      utilizing both system to their fullest DC games should always look better than Model 3 games, but given that the game was originally developed for Model 3 that might not be the case; just like with VOOT.
    • psykom1 wrote:
      This is gangster, but it works.Enjoy that shit.
      Gangster is my middle name! 8)
      The sound is super nice on the game. Really enjoying it!
      "Can be converted/upgraded to Virtua Fighter 3: Team Battle by using a ROM upgrade kit. A simple ROM swap adds new features, a team battle mode and various tweaks and adjustments to the fighting engine, making the game far more balanced."
      So anybody actually did this? the vf3tb mame set has 8 roms:
      epr-20126.17
      epr-20127.18
      epr-20128.19
      epr-20129.20
      mpr-20130.1
      mpr-20131.2
      mpr-20132.3
      mpr-20133.4
      Guess I'll need to order some blanks ... xiaobao_semi on Ebay ok ?!
    • the "CAB IO" board on the Blast City uses a JST RA connector, which seems to match the connector for a floppy drive ribbon cable including the key pin.
      Though, I'm still not entirely sure how this information is useful since it still needs to be routed to a model 2 or 3 filter board or JAMMA or something else.
