bytestorm
Sweden
Got 2 mv6 slots for repair from a friend and have fixed all boards but 1 of the top pcbs..
it had massive corrosion damage and I have patched it extensively, checked all busses for continuity to the connectors.
it will not boot from any slot, and slot 3 wont even show the memory viewer.. and if I check the memory viewer from slot 6 it reads:
0x000100 0x4e45 0x4f2d 0x0a60 0x4f01
the working top pcb gives me:
0x000100 0x4e45 0x4f2d 0x4745 0x4f01
I have been using my logic probe to compare the areas for slot 6 on both boards and the nonworking board seems to have trouble with the signals to/from chip 15 (SDD0-SDD7 according to:
https://wiki.neogeodev.org/index.php?title=SLOT6_board
the working pcb is pulsing nice on all i/o and the non working is just a combination of steady high or low signals.
the 1x 138, 1x 178 controlling the slot selection behaves same on both the non-working and working board, same goes for the 4x 151.
both selects are low on the 244 (chip 15 on wiki).
I am running out of ideas now and getting a bit blind after sitting with the same board for a long time
(I have also cleaned the slots, double checked voltages, resoldered all connector and cart.)
Here is a comparison shot from the non-working (left) and the working board.
01000111 01000101‬ - 4745 (working)
00001010 01100000‬ - 0A60 (non-working)
I am not sure how to interpret this, I mean all other data is read correctly (at least for this range in the pic). That tell me that the 68k adress bus is OK?
The buffer chip 15 mentioned in the first post thats not pulsing ok, thats the Z80 bus D0-D7
attachment.php
Thanks in advance!
ooohhhh!! I will kick myself in the nuts for ever trusting another techs work on a non working board... Jesus. There was a big blob of hot glue with the text "OK" on the solder side.. patching of 8 lines whereas 2 went to the wrong chip, they were mixed up.
Grrrrrrr!! Now slot 6,4 works, 5,3,2,1 has jailbars in the S and C areas. But from here I hope it will be easier to find the rest :)
I spent 2 full days with this bastard.... patching many many traces and at least 5 good hours trying to figure out what else could be wrong..
I invested way to much time into it but I didn't want to give up..
I have a MVS4 stuck in the crosshair. Checking voltages, the upper board is receiving 5V. Still investigating what's going on.
Ah ah, it's a classic.
That's why I hate repairing boards touched by someone else before. If they were proper techs board would be fixed. If it's still faulty then we are in presence of amateur job.
and there were more.. supertiny patch underneath another buffer that had came off and was now touching on one of the other pins... overall this mv6 was a nightmare to repair, both because of all corrosion/acidic damages to massive amount of traces, and the overall condition of the board itself.
but now my friend has 2 fully working MV6 slot motherboards again, so all good :D.
Next up in the pile is a samurai aces pcb. :)
