VodkaGobalsky
San Jose, CA
Hi, my blast city seems to only have enough ground pins for 5 buttons for each player. I'm missing the last ground connection for my last button. What would be the easiest way to solve this? The CPS2 kick harness I bought didn't seem to come with the ground pins connected so I did not have additional ground connectors.
Easiest way is to snip the quick disconnect off your 5th ground. Strip the end of it, Cut a 4" length of 22AWG wire. Strip both ends of that. Then crimp the 4" jumper wire to the 5th jumper you just stripped together using a new quick disconnect. Finally crimp another quick disconnect to the other end of the jumper wire.
easiest way is to wrap a wire around one of the other ground terminals and run it to your other button.The less ghetto way is to create a Y splitter for the ground with spade terminals.
