Creating schematic for the nanao MS2930
Franck 78
France (78)
Hello,
The goal is to do it from photos and a real pcb.
Photos because I need a little help to build an initial component list.
I already have the script using this future partlist to create a KiCad skeleton schematic.
(switched to some fund me support)
Thank you
90% done. At least every component in the spreadsheet is in place. I don't think I forgot some.
Logic of the design is also OK for me , no strange things (or missing links).
what is left to do
-caps values
-zener voltage
A lot of them can be guessed from ms2931 MS9, ...
Nice work so far! Not sure if this will help you or not, but I uploaded some Hi Res photos of the 2930 while I was working on it a while back:
Del
Hello,
@DelsArcade , I did not know about the PCB-D. It is a little more populated than what is in ms2931 service manual.
Does anybody have 2 pictures of this pcb ?
Hi @Franck 78
Do these photos help at all ? I have a problem ms2930 I’m dealing with at the moment so this schematic would be very helpful to many I’m sure . I have tried to take a few pictures from slight angles so you can read the text on the p sub board . Let me know if you want any pictures of the chassis itself .
Cheers
@Franck 78 wow you drew that up quick!
Happy to try take some clearer pictures for you if it helps ? Do you want me to take any measurements on R151 and R159 with my multimetre for you just to be sure?
Many Thanks
Great job @Franck 78 It's very much needed for the community this and from other monitors.
Keep us updated please.
About the capacitors, be careful with the values and the tolerance specially. Sometimes that tolerance can create issues if you don't choose the right one.
Coffee Sent!
Franck has been nice enough to show me a beta test copy of the schematic, its very detailed and easy to follow.
If anyone else is trying to diagnose / fault find their way through a Nanao MS2930 chassis (Like myself) , this man needs all the extra caffiene he can get to complete the task ! :)
@Franck 78 will send through those resistor measurements soon to you.
Cheers.
Sent you some coffee money! Hopefully it helps me bring my MS-2930 back to life. Keep up the great work — really appreciate what you’re doing!
Great stuff, coffee sent. Thanks for sharing your expertise and fruits of your labor with the community.
