In the corner of the chassis you will find a 6-pin header that is unpopulated. That is the connector for RGB with high input impedance used for JAMMA games. You need to aquire a JST PH connector housing and matching crimp pins. The pin-out for the connector is: 1 = red signal, 2 = green signal, 3 = blue signal, 4 = video ground, 5 = C-sync (H-sync), 6 = V-sync.
For 22-26awg wire. There are other pins, for thicker or thinner gauge if needed, but for your purpose 22awg is perfect. I have tried the connector i mention above and it works before posting it
Mais c’est certain que tu peux prendre l’autre s’il est mentionné dans le manuel
Both inputs accept 15/24/31kHz signals, the difference is indeed the input impedance. For example the 6-pin CN101A will also accept an amplified 31kHz signal (e.g. from Invzim's JAMMA expander over the JAMMA edge with mister set to output 31kHz).Doesn't the PFX accept 15khz on the VGA port? I believe it is just a matter of dropping it down to 75ohm on RGB lines and sync stays TTL. Trisync helper will do this as well as some Extron boxes.
Thanks so much buddys, iy's seems the CN101A connector on the chassis.
OK great, thanks. My MiSTer setup is hooked up to a Grundig with the Blast City tube, so the output will be 15Khz by default. If everything works I can start building a .ini file for MiSTer with custom resolutions to make use of the multiformat capabilities.VGA from the Mister to VGA on the PFX chassis is perfect.
If you're unsure of your Mister config, test it on a LCD VGA first, to know it's working, before testing the monitor with it....just to eliminate possibilities.
Best of luck.
Also....the connectors you're showing are POWER (3pin), Jamma standard input (8pin), and 15pin 75OHM DE-15 connector.
As noted above, you can input 15khz and 31khz into either the 8pin or 15pin inputs, what will matter is the impedance.
So on the mister, you could setup the output as 15khz and it would still work over the vga cable. (that wont work in testing with the LCD panel i mentioned above)
