Everyones entitled to their opnion. I stand by my position. VGP sells ossc pro without remote for usd335 equiv.
You can use converter and transcoders but why would you ? It adds so many cables and parts in process.
Hey buy whatever do whateve suits your need. No one has has to agree with me if they think doesnt make sense. That’s fine. I have spent plenty of time with down scalers from gbc to TV1 to emotias to super emotias and all the others. I think OSSC Pro is the best when it comes changining the singal and then display picture on a CRT. Hence shared my opnion.
If in future ones's setup or needs change OSSC pro will be of much better use than UVC.
Agree to disagree. I’ve been running the UVC forever, probably before you even got into the hobby. You don’t need a complicated device as a full-fledged console up/downscaler. Besides, the OSSC Pro’s main function is upscaling. Downscaling is a nice addon feature, but the UVC is a dedicated downscaler.
I just think you’re butthurt from not being able to buy a UVC for the price you wanted so you’re trying to slander it now. But like I said, the deals are out there, “patience young padawan”.
I’ve also tried other devices like the GBC AIO (which doesn’t support 24khz), couple Extrons, etc and the UVC has always been the cleanest and easiest to install.
Here are Some example pictures of running my UVC in my Astros and Aeros.
Nanao MS9 in the Astros, MS8 in the Aero.
Super clear and crisp. 24khz is much nicer than downscaling to 15khz for the Naomi. I would say the UVC is perfectly made for the Naomi altogether.
I’ve also built my UVC into my Sega IO/Jamma stack for the easiest installation. I built 2 of these, and my 3rd UVC is going into a whole different project (eventually).
This gives me downscaling, non-laggy IO, with cps2/3 kick harness support.
The UVC is for arcade cab owners who want to downscale arcade games.
If you want a good device to downscale consoles, sure, go with the OSSC Pro or equivalent.
