freddiefiasco
I have a Street Fighter Zback HS5 cab with a 25” RCA A63ADT10X05 CRT. I added a T8 LED bulb to the marquee to complete the cab, however, when the CRT is plugged in at the same time as the Marquee, the marquee doesn't power up. When I unplug the CRT, the marquee bulb works.
I noticed that both of these are connected to the same terminals into one transformer. I didn't measure the power draw going into the CRT (too afraid of these suckers when energized) but I did measure the power draw from the CRT bulb and it's around 9-10Volts.
Any hints/tips I could look into to get both CRT and Marquee to work at the same time?
Thank you
Thank you
