All,
I'm releasing an update pack that fixes a few bugs in v2.0 including the two long outstanding bugs regarding Super StreetFighter IV, and BlazBlue CS2.
Here is what this fixes:
- Menu booting to black screen
- Random reboots after exiting games when an RFID reader is connected
- BlazBlue CS2 only booting 480p when using a JVS I/O and an iDmac is installed
- Super StreetFighter IV issues when using Fast I/O
- Screen turning off after leaving some games in attract mode for 20+ minutes
Here is how to install the updated files:
- Download the update pack from here: TTX2Multi v2.0 Update Pack
- Copy the "TypeXmulti" and "WINDOWS" folders to the root of "TTX2Multi[C]", overwriting any existing files.
- If your using a Windows computer you may have to "Unblock" the three executable included in this update pack after you've copied them to the multi drive. ( "ttxrun.exe", "ttxshell.exe" inside "C:\TypeXmulti\assets\" and "ttxmenu.exe" inside "C:\TypeXmulti\menu\" ). To "Unblock" an executable, just right click the file and select "Properties". In the "General" tab click the "Unblock" button. If you do not see an "Unblock" button, you shouldnt have to worry about this.
- Safely eject the multi drive from your PC and your done.
To fix the issue with Super StreetFighter IV, first install the update files mentioned above. Next add "pollrate=10" to the "config.ini" file found inside "Super StreetFighter IV Arcade Edition 2012\TypeXmulti\" on the "TTX2Multi[Games]" partition.
When your done the "config.ini" file should look like this.
if anyone has any issues, please post it up here and I'll help you.
