Thanks, everything is working on my TTX2 (7900GS, P4 and 3Go and Mitsu' JVS IO helper PCB).
But for me, the menu (NXL) is too slow and I have strange issues :(
In the setup menu, up and down are inverted (I don't have this problem in games).
Other point is when scrolling left and right in the different games. I don't understand how things are moving but it looks like it's not just moving by 1 games to the rigtht or 1 to the left.
I think I will come back to niko's menu for the right moment, but thanks anyway for your great work.
finished installing the image file on the hard drive boot up and it gives me a blue screen error 900?
Hello Niko.
today i just install the multi from the torrent with 128 GB file.
The menu appear and the games can play. But there are two problems.
1- There is an error about of the Nvidia Card. İt wasn't there before with the 1.3 version multi
2- I set on dipswitch 2 for the 720p. But in my tv there is some resolution problem. You can see the picture. Left side of the screen.
1.) What graphics card are you using? Is it the stock card? If your using the stock 7900GS then your PSU may be going bad. I've seen this message before when trying to run really beefy cards in the X2, like the 7950GX2.
2.) It looks like your TV/Monitor is simulating overscan. You will want to adjust the settings on the monitor in order to make the screen the correct size. The menu outputs exactly a 1280 x 720 16:9 image.
Sorry Niko. I just opened the Typex2 and i realise the power of the Graphic cards unplugged. I dont know how it unplugged. Anyway there is no error message anymore.
I will try to adjust settings for my TV.
and one more thing. Kof Mira has graphical glitch. is it normal when we are playing 720p ?
Ahh, easy fix :)
There shouldn't be any glitches, Do you have a picture of the glitch or can you explain it to me?
You can see the black pixels.
it is not only Kof mira has got it. There is some another games have same problem. For example Giga Wing
Im trying all the games.
16:9 games are working good. Street Fighter and Kof Series.
But 4:3 games like Examugames and the others have problem.
My Typex2 is trying to open all games as 16:9.
i think this is the problem.i dont know maybe it is about my TV. Bcs some games has got wrond adjust.
It looks like either a problem with your graphics card or the installed driver
I think your graphics card is dying. I also investigated the KOF MIRA and I do not have any of the pixel problems on the multi drive or the offical game drive.
Good news is that its easy and cheap to replace the graphics card. I have a write up on here on how to flash a regular GeForce 7900GS with correct BIOS to run on the X2.
Thats a bad New
So if the card is dying do you think it Will be problem with all of the game?. Not only 4:3 games
I had a video card go out in my X2 as well. The problem will get gradually worse on all games as time goes on. The good news is that you purchase a GeForce 7900 GS for relatively cheap $15~30 off eBay. Niko has an easy to follow guide on how to flash a custom bios to the graphics card, so that the X2 will accept it. https://www.arcade-projects.com/for...geforce-7900-with-elsa-979-bios.916/post-9810
thanks for the information.
I think maybe you are right about it.
when i set the sipstwitch 2 OFF ( 480p) there is no graphical problem with the all games. But at the 720p problems with 4:3 games.
i will try to find 7900GS in my country, or will order from eBay
Hi,
why battle fantasia not start ?
dvseb.
How is your monitor connected to the X2?
Battle Fantasia is one of the few X2 games that tries to read EDID information from the monitor. If the dips are set for 720p and you are not using a DVI-I to VGA adapter with your monitor, the game will not be able to read the EDID information and it wont start.
