A GUIDE FOR DEPENDABLE TAITO GNET CF CARD WRITING WITHOUT MICRO$OFT WINDOZE (ALMOST)
lowlight
Dallas, TX
Hey Everyone,
Do you have a newly upgraded/BIOS flashed (2011 Bios) Taito G-NET board ready for CF games? Have you been trying to write/flash your ____ CF card with limited to no success in Windoze 7 or higher? Do you keep getting Unable to open file or error writing hunk 0 errors from your current version of MAME's CHDMAN? Do you get odd errors from whatever version of GNETFlasher.exe you happen to be using (eg. CF reader/writer not showing up, stops writing half way, unable to start write, etc.)? Have you tried just about every guide on the internets concerning getting this to work on a Windoze system, only to come away thinking your CF cards, CF reader/writer or version of Windoze is keeping you from making a valid GNET card? Do you have access to a physical (or virtual machine) of MAC (OSX) or some form of Linux? Well then this guide is for you.
REQUIRED ITEMS:
  • Reliable USB Compact Flash reader/writer (or some type of PCMCIA reader/writer to use with PCMCIA CF Adapter)
  • A Compact Flash Card (64MB to 2GB; although 64MB should be more than enough for most games/conversions)
  • A Reliable PCMCIA (PC Card) CF Adapter (SanDisk brand seem to be the most dependable)
  • A Physical (or Virtual; untested) Mac/OSX system or Linux variant able to read/write to USB devices
  • ***A Windoze system (VM is fine too) to run CHDMAN for CHD image extraction
NOTE:
*** SDLMAME's CHDMAN can be used instead for this task, making it completely *NIX based. This, however, will also require the SDL Runtime Library installed before hand.
INSTRUCTIONS (Tested with a MAC; Not verified on *NIX, but should work):
  1. On a Windoze system, use MAME's CHDMAN.exe utility to extract your chosen game to an .img file (example below is version .146 or higher).\path\to\chdman extracthd -i [tt]\path\to\chaoshea.chd -o \path\to\chaoshea.img
  2. Move/copy your new image file to the MAC/NIX system.
  3. Connect your CF reader/writer (or PCMCIA CF-Adapter) to your MAC/NIX system.
  4. Verify the drive's location in the DEV chain by doing one of the following from a terminal window:
    MAC > sudo diskutil list*NIX > sudo fdisk -l
  5. Review the output of the command, and locate the root disk that matches your connected device. Assuming you only have one internal disk and nothing else attached, on a MAC this would be /dev/disk1 and on *NIX this would be /dev/sdX (X is the main letter that matches up with the USB chain, usually "a").
  6. (If you already know your CF Card is zeroed out/raw, skip to next step) Zero out your CF Card; this example shows this happening to disk1(OSX)/sda(NIX):
    MAC > sudo diskutil zeroDisk /dev/disk1*NIX > sudo dd if=/dev/zero of=/dev/sda
  7. Write the GNET image file to your newly zeroed card (the "r" is to write to the RAW block device; not essential, but does speed things up):
    MAC > sudo dd if=/path/to/chaoshea.img of=/dev/rdisk1*NIX > sudo dd if=/path/to/chaoshea.img of=/dev/sda
  8. Unmount/Eject the CF/PCMCIA card from the OS.
  9. Place the CF Card in your PCMCIA Adapter (if not already there), and load into your Taito G-NET board.
  10. Power on your JAMMA system.
If everything worked without errors to this point, you should see your G-NET system load with two progress bars: the first for loading the game into RAM, and the second for preparing the loaded RAM for initialization.
TROUBLESHOOTING:
  • If you see the following error 000001 SYSTEM ERROR to 0006XX SYSTEM ERROR, this means the card was recognized, but does not work correctly for some reason.
  • If you see 000777 SYSTEM ERROR, this means your BIOS wasn't correctly flashed (outside of the scope of this guide).
  • If you don't see any system errors, the game loads, but then stops abruptly after initialization/loops repeatedly through color-bars and attempts to reset, this usually means the CF card itself is not compatible (NOW you can buy a new card).
I hope this guide saves someone a headache (and money in their wallet from buying unnecessary tools/parts that may/may not fix anything).
Solid guide. I just use a bash script on ubuntu. It should work fine on a mac too since you're already using dd. I run it on a system with only one disk, so I know the CF will always be /dev/sdb. It should go without saying to set the device first if your PC has multiple hard drives, or you can accidentally erase data ;)
I leave this in a directory with all the raw files (extracted CHDs). Run it with the game name as the only argument and it will erase/flash $device for you. Use the whole block device (i.e. $device should not be /dev/sdb1 but just /dev/sdb)
Code:
#!/bin/bash
#Set device path
device=/dev/sdb
if [ -z $1 ]
then
echo "Please provide a game name! exiting"
exit 1
else
echo "Flashing $1 to $device"
fi
#check for mounted partition
if [ -b "$device"1 ]
then
echo "unmounting $device1"
umount "$device"1
else
echo "device is unmounted, proceeding."
fi
#check for card itself. #doesn't work. /dev/sdb exists regardless
#if [ -b "$device" ]
#then
#echo "card is present. Proceeding with flash."
#else
#echo "No card found. Exiting"
#fi
#prompt to erase the card.
echo "Erase first? (recommended). y/n (or ctrl-c to abort flash)"
read erasecard
if [ $erasecard == "y" ]
then
echo "Erasing card. THIS WILL TAKE A WHILE. BE PATIENT."
dd if=/dev/zero of=$device
else
echo "Not erasing card. Proceeding anyway"
fi
sleep 5s
# final flash
echo "writing card. THIS WILL TAKE A WHILE. BE PATIENT"
dd if=$1 of=$device
echo "Done. Have a nice day :)"
Solid guide. I just use a bash script on ubuntu. It should work fine on a mac too since you're already using dd...
Nice script. It would need to be modified slightly for mac use, as drives are usually mounted as /dev/disk1, /dev/disk2, /dev/disk3, etc.
Precisely, it would have to be altered for that reason (diskX versus sdX). I should stress that main reason I chose to forgo scripted solutions in general for the guide was because, without explaining the script's logic, would obfuscate the inner workings of what's happening on a *NIX type system for folks that don't usually drill down. When I was first starting off in my collecting, I often found that there were a good deal of well meaning tuts and guides that would sometimes (unintentionally) tersely run you through a thing, leaving you to either sink or swim. I have a lot of Jr. Software Engineers that work for me in my normal day job that I typically can't take that sort of approach with; it's best if the steps are explained and laid out for them. So, it's colored my writing style as a result. That all being said, I had always assumed more savvy hobbyists would automate my guide in very short order. I'm glad the info in general is useful!
Micro$oft Windoze! It's like I stepped back in time 20 years!
Anyway, I had these issues with CHDMAN and Gnetflasher. What solved it for me was using CHDMAN to make the CHD into a regular image file:
chdman extractraw -i gnet_game.chd -o gnet_game.img
And then with HDD Raw Copy Tool I extracted the image to the CF card.
Should I have said Micro$haft WinB@it instead ;) ? It's good to hear that your solution worked out for you :) ! I just wanted to provide an alternative route that was *NIX with as few outside/3rd party applications as possible (dd and diskutil are native in their respective Operating Environments; too much 3rd party dependence can add fragility to a solution), as *NIX solutions don't seem to be covered as often in the community at large.
