FS Adaptator Naomi/Chihiro/Triforce via ATX v2 Now with io support!
I bought one of these recently for the Naomi setup in my Astro City cab previously I used the Naomi Sun PSU with a stepdown if I use a PC power supply do I no longer need to use the stepdown converter?
Hello Swisstoni,
The adaptator supply only Naomi CM and/or io board.
Not use for supply all the Cab (like CRT etc..)
So yes you need to use your stepdown too.
BR
The Astro City cab is powered by a seperate stepdown, the Naomi is powered by a sun psu which is plugged into its own stepdown so with this will I no longer need a stepdown for the naomi if I use a PC power supply?
The naomi board uses a seperate stepdown converter to the cab
Hello Swisstoni,
BR
Hi Swisstony,
So yes if you talking about the sun power supply
This one :
Yes it can be remplaced by an ATX with my adaptators ;)
But I don't remember if you ordered me the io adaptator.
This one :
Because you need that for io supply (io is also supply by the sun power supply)
I hope this answers your question.
BR
sorry missed the reply no I didnt get an IO adapter please can I order one.
Hi Swisstony,
This one :
This one :
BR
