Afterburner power wiring
mundy
Rewiring an afterburner that had bits of the loom removed, chopped off and the transformer has been changed so standard Sega colours in the manual no longer apply. Specifically looking for the wiring for bridge rectifier and amp power board. The amp power board has five connectors 3 in two out the three in are listed AC CT AC, I presume the ACs in are from the transformer but I don't seem to have a center tap on the loom so no idea what iam missing, the output is 12v and Gnd going to the amp which is fine but the 12v has another cable coming off it, not sure what this second 12v powers? The relays? Also the relays are fused but no wires so pin out would be handy iam guessing these follow standard wiring colours per the manual but both blue and white wires (maybe its a ground?) are through fuse blocks so what voltages are these? A few pics around the bridge recitifyer/capacitor and the power board for the amp would be handy if anyone had them. Thanks. Also as an aside why cant the Amp be powered from 12v from the switching psu?
