Astro city power supply replacement
cma019
hong kong
Hello all, I broke the V.ADJ pot while adjusting the 5V, and since it’s quite old, I’m thinking I should replace it as well.
However, I’m unable to find the 400-5198 model with the white connector. I can only find versions with the black connector.
Does anyone know if these are interchangeable, or would I also need to change the wiring harness?
thanks a lot!
Hey I converted, my white plug psu to the black version. I just brought the correct te amp up plugs and depinned the white plugs and then inserted the pins into the new black plugs. Took about 10 minutes. I just printed both psu wiring diagrams and moved the wires one by one.
Cheers
