Hi Everyone,
Just after Christmas I got an Astro City! $650 on ebay with a busted monitor, so I figured I'd give it a shot. This is my first arcade machine, and the one I've wanted most as a Sega fan. I'll be documenting my progress and fixes here. My goal is to make it a 2 player machine, green/pink like back in the day with tons of Capcom, SNK, and Konami games in it. Not sure what the best hardware solution is yet, so I'll be using the Neo Geo MVS for now.
This is how I saw it on the listing. Looks good, owner said the screen was working before, but doesn't anymore. Probably needs new caps or fuses they mentioned. It does play games as in there's sound and the buttons work. it's just the monitor that has issues.
Amazingly, it fit into a Honda Fit. But there's no wheels, legs, or the foot plate, I realized. Oh well, I'll try to find those later.
After a general cleaning, I started working on the control panel. It looks like it's been painted over? There's also this strange plate over the coin entry. I drilled out the rivets and removed it. Someone must've ripped off the coin entry back in the day, and the operator bandaided it with this.
After wet sanding and puttying up the holes and ditches, it's ready for painting. Except I splattered the paint and have to try again. The putty keeps shrinking too, so I'm still adding more layers to fully plug those holes around the coin entry. I'll come back to this later.
Next focus was on the lights. I ordered a new starter bulb fg-1e and an 18 inch, 17 watt T8 fluorescent light and it works! The tube was a little longer than the metric Japanese bulb in there, but it still fit nicely.
And now for the big issue. The monitor. A Nanao MS8 29FSG. I took it apart and checked the fuses. F902 was blown. I thought "cool! This will be an easy fix!" I popped in another fuse and it blew again. Darn.
So I start to dig deeper. A couple caps are noticeably leaking so I'll definitely recap the chassis. But I also notice some discoloration and burnt solder points around Q532. Apparently this is the HDT (Horizontal Drive Transistor). So I get a new old stock HDT, pop it in annnnnd it blows the same fuse.
I do a lot more research and find that someone else had the exact same problem as me with the same monitor! So I'm reading into this thread and watching his video on what he replaced, and I plan to do the same. I've ordered the same replacement parts and I'll be putting them in soon.
https://forums.arcade-museum.com/showthread.php?t=426426
The parts I'm replacing are the voltage regulator (NTE2311), HDT (new old stock, 2SC268, and horizontal output transistor (new old stock, 2SC4288A)
In the meantime, I've recapped the chassis. Just waiting on those extra parts and the Filter cap which I forgot to order.
I'm currently asking around for the missing foot plate and leg levelers. I found the wheels on ebay, but they're missing the hardware to attach the wheels. I might have to just use bolts and washers. Also ordered a new control panel (the metal part with art) from Alberto on ebay. I've read good things about him everywhere.
That's all for now!
That's all for now!
