ATX to NAOMI
deibit
Germany
Hi!
Is there someone doing ATX->NAOMI (with jump start) Power cables?
I could but I don't have any parts at home :( Do you need to save the PSU for something else? If not, just do this :)
Yes i could hack the Power Supply connector but the issue remains.. (the JVS side connectors)
And since the Power Supply is a Tier1 PSU (=expensive), I would like to avoid hacking it :)
any advice on a good/cheap crimp tool for this connectors? they appear to be extremely expensive...
I just got a bunch of ATX extension cables, I will order later the JST connectors and pins.
I have here a PA-20 crimp tool, I'm not sure it will work for this application (might be that the wires/pins are too big for it), but it's worth a try..
else I could do the "needle noose pliers" thing :)
Thanks!
Just discovered that my supergun won't power my Naomi with a net dimm/net booting, so bookmarking this page for later reference.
Goodness gracious Naomi is a mess of wires and pieces and ugh
Does anybody do any ATX PSU Services to work for a Naomi ?
looking for someone to get a ATX PSU who either has the parts from a SUN PSU and have it produce enough power for a Naomi / NetDimm.
