FS (AUS) - Cyberlead 1 Parts
DRAGONKZ
Sydney
Anyone in AUS after any Cyberlead 1 plastic parts?
I’ve started working on making the “best” cabinet from both that I had, and currently have the following bits I don’t need if there’s any interest:
*Both side plastics, some cracking +hole in top corners
*Monitor cover/speaker grille plastic
*Speakers
*Speaker mounts/plastic triangle shape
*Rear wheels
*Front leg levelers
*Coin mech/reject lever assembly
*Wiring Looms
Given the size/fragility it’s likely better to try and not ship these too far, but if someone overseas wants them then we can see what we can do.
The other parts (full wiring, control panel…etc) will be added to this as I’ve finished doing that section on my machine.
Cheers
Ooh, parts!
Is your panel 1P or 2P? I wouldn't mind a 1P panel for mine.
As for the sides, mine has a small hole in each side, cracked but whole might be better? I'd like to know more.
The only other part I'm looking for is a marquee in better shape than mine, with the multitude of dim LEDs.
Sorry no 1P panels, I've got 2 x 2P panels.
Sorry, by cracked I meant cracked + holes :P You're welcome to take them if you want to try repairing them?
You just want the DMD itself you mean, or the full assembly including cover, power supply, IO...etc?
***Added more bits to the top post***
Adding the power supply bracket/wiring/buttons, and control panel main metal holder to the list of parts available before they are scrapped.
Anyone need any of these bits?
Hi, I'm still fixing up my Cyberlead in NZ. I now need a main controller board if you wanted to sell one? Mine is not working properly. Picture attached for reference
Thank you. 😊
Thank you. 😊
That’s from a cyberlead 2? Do your cabinet have the controller/memory card ports on the panel under the monitor?
Ppre
I have a Cyberlead 1. The board I need in the photo is located above control panel under monitor. I've finally got power to the marquee but it just shows all LED lights red. If I press any of the test buttons on that controller board nothing happens. I thought I'd try my luck replacing this part now.
That’s the main JVS IO for the cabinet, and that version you have is from a Cyberlead 2… @xodaraP you’re running the same right? I think he is the only other person with that IO in a Cyberlead 1.
My spare IO is 2 revisions earlier, there will be some functionality differences with mine around DMD colour support and a bunch of mid/late gen system 12 games won’t work via JVS. (There’s some threads on here)
But if it’s a case of no cabinet or a cabinet with a few “drawbacks” then I’m ok to sell the IO as long as you’re aware of the above.
Sounds good I'll take a chance at this point. Send me a PM
Thank you. 😊
If you wanted to sell your non working one I’d love to buy it so that I can dump the chips and learn more about it. You have the only other one of that revision I’ve ever seen
Almost all the parts are gone now, I gave some away, tossed some, and sold the bulk of the wiring/boards to @killer7.
His cabinet is literally almost missing every factory board and wire, so made sense to put most of my spares towards getting that working.
At this stage I really only have the following left if anyone needs any?
*Full DMD assembly - currently reserved in case killer7 also needs something
*The Namco JVS to jamma adapter - also reserved for above
*Glass and both clips for the control panel instruction window
*Main control panel plastic with a 2P 6B panel
