drfunk2k
From USA / Nanjing, China
Axun Workshop - DB-USB Converter (DB15 to USB)
PRICE:
$43.00 + shipping
SHOP:
http://www.axunworks.com/product-p669377.html
FEATURES:
Allows USB controllers and arcade sticks to be used on DB15 ports on superguns.
Button Config:
Press and hold any three buttons without letting go, and turn on the power. Wait until the green light flashes, you can enter the desired 1-6 button config you want.
Controllers Supported: (Anything PS4 works) +
These are the controllers we tested so far:
Razer Panthera PS3/PS4
Victrix Pro FS
Qanba Dragon / Obsidian
PS4 Pad Support
Official MS XBOX-ONE pad
HORI RAP4 PS4 stick
Hori FPS Pro PS4 pad
Venom PS4 stick
Sanwa GGXRD PS4 stick
3rd Party PS3 support
PS3 / X360 support (Madcatz, etc...)
Logitech / Logicool controllers
Retro-bit Sega Saturn Wireless 2.4 ghz pad
This has not been tested. If it is a DIY product, why not use the direct connection method. That's the best response. For example DB15 to button
This is more for users who have built multi console arcade sticks that would like to use it for their arcade supergun also. My assumption it will work fine based on PS4 compatibility.
This product is using USB2DB15 firmware?
It is not, there is a custom chip inside, Axun product does not have as much compatibility as the USB2DB15 project, but we don't have all the controllers to test with, the following are tested
Victrix Pro FS
PS4 Pad Support
HORI RAP4 PS4 stick
Venom PS4 stick
When I connect usbtodb15 to jamma extractor, buttons 1 and 2 continue to be pressed
It's no use remapping, and it's the same if you put the usbtodb15 back in.
Can you help me with this problem?
@pyjmj05 did you ever get this handled?
Sorry, if I am having trouble with your question. You are saying that buttons 1 and 2 are continually active?
What controller are you trying to use? The one in the picture?
Does it use a brooks board?
Let me know,
DrFunk2k
