LittleMegaGamer
Never mind @CamoYoshi Finally It is working now! I didn't clicked on "SET" after setting the IP address so the board was resetting the default IP. They are woking together now!I will try to use the HashTools , never done before, but I finally sorted to exted the 8GB WiPi img and so moved the roms from the 32GB img.
My proble now is that I can't make the NetDimm and the Pi working together. The IP Adress settings of my NetDimm board got lost any time I goes in the service menu (?). What exactly is the next passage after setting the NetDimm board? Is correct to turn arcade board and Pi together to do this first setting?
I tried to lunch some games and gotr a message "not dimms available for this game" (?)
I did have much tuime to dedicate but I will be back and try. Thanks for any tips
You are right, they come with different sizes and my one is not 31.9GB, but I tested the 32GB img with a 64GB SD and got the same result. Like I said, probably something wrong with my 32GB img file, but you know all the story I don't know what else to do with it...
I still think I need a working 32GB img if someone could share it please.
As mentioned before I moved the roms from my "not working" 32GB img to my "working" 8GB img and probably some games are corrupted (as I think my 32GB img is):
- Some games run ok,
- with some games like CVS2 after the loading time I get message "Caution 51 - Game assigments are incorrect. Set correctly in system assignments of test mode"
- some games like VF4 won't load, getting a message from the launcher "no dimms available for this game".
I don't think that happen to a working 32GB img with everything set in
