Battle Bakraid Unlimited UO131 and UO721
nem
Immortal
Finland
I bought sheepnova's slightly broken Battle Bakraid Unlimited PCB. It boots to an eeprom error. The eeprom on the board has already been replaced at one point, it's a CSI 93C66S. I assume a 4kbit EEPROM is correct for this board? Can someone check their board? With the jamma edge facing down, it's on the top, to the right of the Z80, UO721.
The board also has the 4-pin reset IC replaced with a 3-leg T518B. Looks bad on an expensive board. I might change that as well. Is the original a PST575 as written on the silkscreen? This one sits right above the 32MHz X011 crystal, UO131.
Thanks!
I checked on mine, the UO721 is a 93LC66A and the UO131 is a 575D. Good luck for the repair!
Reactions: nem
