@buffi and everyone here
Everything is not perfect in this world, I don't know if a made something wrong.
To upscale the betsubetsu I want to use a Gbscontrol. The GBS control works fine with spitfire and scary diy jamma output.
For working, I've to make a horror cable
Mini din8 to VGA
I made it using this shema using the RGB
And the one from the github
If I'm right, the view is in front of the connector, I'm looking the female connector.
I test my wire continuity with a multimeter.
And I'm out of idea, if you've got one?
Maybe I can't make it to work like that.
Thanks
Edit : weirdly it works, I've got some perturbation of the signal, I will investigate.
