Well, burned @caius 's file, wired 10 to 8, and popped it in.
Now the game gets a title screen and coins up and plays!
But there are awful sync issues, and the video is all scrambled, ha! This is better than before where it didn't do anything.
Sync goes to R15, and into pin 8 of 7L, which looks to be replaced. 7L is an HD74LSO8P, it has pin 9 tied to pin 10 of 8L which is a M74LS161AP.
Going to look at @ShootTheCore 's PCB pic and see what's what.
Both PCB's have the same wire between 7L and 8L, but mine does not have the ceramic cap.
In my experience, if the /CE lines are permanently tied to GND, you can ignore them when you declare I/O in equations, it will work the same.But if they get toggling signals, then you have to declare something like this as inputs :
PIN 17 = CE1
PIN 18 = CE2
and like this (for each output)
D0.oe = !CE1 & !CE2;
What I wanted to say is it's still possible to have 3 state outputs if one of the /CE lines isn't tied to ground our if both are connected together to something different to ground.Even if the GAL only have one /OE input.
Forgive me, because I'm still new at this, but I'm really trying to learn. Tied to GND would mean it has continuity with the GND on the JAMMA edge, right? I just don't want to give the wrong answer because I misunderstood the terminology.
If so, then Pin 14 (CE2 according to the pinout of 82S129) is tied to GND, and 15 (A7) is not.
What about pin 13 (/CE1)?
Yes, sorry, I made a typo, I was meaning pin 13 ad 14, the two /CE lines.If they are both tied to GND we can disregard them even if we could declare them in I/O pin assignement as tristate.I always do in this way and it works.
Yes, sorry, I made a typo, I was meaning pin 13 ad 14, the two /CE lines.If they are oth tied to GND we can disregard them even if could declare them in I/O pin assignement as tristate.I always do in this way and it works.
According to what rewrite said pin 13 has to be rerouted to pin 11 of the GAL (/OE) and used in the equations (no need to declare pin 11 as /OE if you use the .OE syntax).
According to what rewrite said pin 13 has to be rerouted to pin 11 (/OE on the GAL) and used in the equations (no need to declare pin 11 as /OE if you use the .OE syntax).
OK, now I read it it.So pin 13 is not tied to GND but it's toggling hence I have to declare the OE equation for the four outputs.I will upload the updated .JED in some time.I will not use pin 11 since it's the OE for a GAL set as registered device and we don't need this.Instead I will use pin 17 of the GAL16V8 which matches exactly the BPROM pinout (like I did for inputs and outpus)
More pics of added caps and jumper wires on my board in case it’s helpful:
These are factory fixes, you can find them on many Capcom boards of same era (Side Arms, Section Z, etc..)
To me this isn't correct, the /OE input of the GAL can be used regardless of its mode.
Also if using pin 17 as you said you lose the tri state functionality.
Think whatever you want but I always do in this way and it worls all the time :)
PIN 11 of a GAL16V8 is only input in combinatorial mode and OE in registered one.
I could use pin 11 as OE instead of pin 17 but it's the same thing since, as said, in combinatorial mode pin 11 is input only.I use pin 17 since it matches with pin 13 of the BPROM in the socket.
I simply assign pin 17 as CE1 decalring it as input
CE1 PIN 17;
Then write an OE equation for each output:
D0.oe = !CE1;
D1.oe = !CE1;
D2.oe = !CE1;
D3.oe = !CE1;
PIN 11 of a GAL16V8 is an input in combinatorial mode and OE in registered one.
Can we have an open discussion?
If I'm wrong I'm ok to be corrected but there's no reason to be rude.
So what you mean is if you do something like that:
'pin19'.OE = !'pin 17'
You get the high Z state working on pin 19 when pin 17 is low?
Can we have an open discussion?If I'm wrong I'm ok to be corrected but there's no reason to be rude.
I simply assign pin 17 as CE1 declaring it as input
CE1 PIN 17;
D0.oe = !CE1;
D1.oe = !CE1;
D2.oe = !CE1;
D3.oe = !CE1;
Why using pin 19?In my adaptation pin 19 is A7 of the BPROM.
For a better understading here is the structure of the equations before compling them:
"Inputs
A6 PIN 1;
A5 PIN 2;
A4 PIN 3;
A3 PIN 4;
A0 PIN 5;
A1 PIN 6;
A2 PIN 7;
A7 PIN 19;
CE1 PIN 17;
"Outputs
D3 PIN 13;
D2 PIN 14;
D1 PIN 15;
D0 PIN 16;
Equations
D0 = !A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
# A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
# !A0 & A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
# A0 & A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
# !A0 & !A1 & A2 & !A3 & !A4 & !A5 & !A6 & !A7
# A0 & !A1 & A2 & !A3 & !A4 & !A5 & !A6 & !A7
# !A0 & A1 & A2 & !A3 & !A4 & !A5 & !A6 & !A7
# A0 & A1 & A2 & !A3 & !A4 & !A5 & !A6 & !A7
# !A0 & !A1 & !A2 & A3 & !A4 & !A5 & !A6 & !A7
# A0 & !A1 & !A2 & A3 & !A4 & !A5 & !A6 & !A7
# !A0 & A1 & !A2 & A3 & !A4 & !A5 & !A6 & !A7
# A0 & A1 & !A2 & A3 & !A4 & !A5 & !A6 & !A7
# !A0 & !A1 & A2 & A3 & !A4 & !A5 & !A6 & !A7
# A0 & !A1 & A2 & A3 & !A4 & !A5 & !A6 & !A7
# !A0 & A1 & A2 & A3 & !A4 & !A5 & !A6 & !A7
# A0 & A1 & A2 & A3 & !A4 & !A5 & !A6 & !A7
# !A0 & !A1 & !A2 & !A3 & A4 & !A5 & !A6 & !A7
# A0 & !A1 & !A2 & !A3 & A4 & !A5 & !A6 & !A7
# !A0 & A1 & !A2 & !A3 & A4 & !A5 & !A6 & !A7
# A0 & A1 & !A2 & !A3 & A4 & !A5 & !A6 & !A7
# !A0 & !A1 & A2 & !A3 & A4 & !A5 & !A6 & !A7
# A0 & !A1 & A2 & !A3 & A4 & !A5 & !A6 & !A7
# !A0 & A1 & A2 & !A3 & A4 & !A5 & !A6 & !A7
# A0 & A1 & A2 & !A3 & A4 & !A5 & !A6 & !A7
# !A0 & !A1 & !A2 & A3 & A4 & !A5 & !A6 & !A7
# A0 & !A1 & !A2 & A3 & A4 & !A5 & !A6 & !A7
# !A0 & A1 & !A2 & A3 & A4 & !A5 & !A6 & !A7
# A0 & A1 & !A2 & A3 & A4 & !A5 & !A6 & !A7
# !A0 & !A1 & A2 & A3 & A4 & !A5 & !A6 & !A7
# A0 & !A1 & A2 & A3 & A4 & !A5 & !A6 & !A7
# !A0 & A1 & A2 & A3 & A4 & !A5 & !A6 & !A7
# A0 & A1 & A2 & A3 & A4 & !A5 & !A6 & !A7
# !A0 & !A1 & !A2 & !A3 & !A4 & A5 & !A6 & !A7
# A0 & !A1 & !A2 & !A3 & !A4 & A5 & !A6 & !A7
# !A0 & A1 & !A2 & !A3 & !A4 & A5 & !A6 & !A7
# A0 & A1 & !A2 & !A3 & !A4 & A5 & !A6 & !A7
# !A0 & !A1 & A2 & !A3 & !A4 & A5 & !A6 & !A7
# A0 & !A1 & A2 & !A3 & !A4 & A5 & !A6 & !A7
# !A0 & A1 & A2 & !A3 & !A4 & A5 & !A6 & !A7
# A0 & A1 & A2 & !A3 & !A4 & A5 & !A6 & !A7
# !A0 & !A1 & !A2 & A3 & !A4 & A5 & !A6 & !A7
# A0 & !A1 & !A2 & A3 & !A4 & A5 & !A6 & !A7
# !A0 & A1 & !A2 & A3 & !A4 & A5 & !A6 & !A7
# A0 & A1 & !A2 & A3 & !A4 & A5 & !A6 & !A7
# !A0 & !A1 & A2 & A3 & !A4 & A5 & !A6 & !A7
# A0 & !A1 & A2 & A3 & !A4 & A5 & !A6 & !A7
# !A0 & A1 & A2 & A3 & !A4 & A5 & !A6 & !A7
# A0 & A1 & A2 & A3 & !A4 & A5 & !A6 & !A7
# !A0 & !A1 & !A2 & !A3 & A4 & A5 & !A6 & !A7
# A0 & !A1 & !A2 & !A3 & A4 & A5 & !A6 & !A7
# !A0 & A1 & !A2 & !A3 & A4 & A5 & !A6 & !A7
# A0 & A1 & !A2 & !A3 & A4 & A5 & !A6 & !A7
# !A0 & !A1 & A2 & !A3 & A4 & A5 & !A6 & !A7
# A0 & !A1 & A2 & !A3 & A4 & A5 & !A6 & !A7
# !A0 & A1 & A2 & !A3 & A4 & A5 & !A6 & !A7
# A0 & A1 & A2 & !A3 & A4 & A5 & !A6 & !A7
# !A0 & !A1 & !A2 & A3 & A4 & A5 & !A6 & !A7
# A0 & !A1 & !A2 & A3 & A4 & A5 & !A6 & !A7
# !A0 & A1 & !A2 & A3 & A4 & A5 & !A6 & !A7
# A0 & A1 & !A2 & A3 & A4 & A5 & !A6 & !A7
# !A0 & !A1 & A2 & A3 & A4 & A5 & !A6 & !A7
# A0 & !A1 & A2 & A3 & A4 & A5 & !A6 & !A7
# !A0 & A1 & A2 & A3 & A4 & A5 & !A6 & !A7
# A0 & A1 & A2 & A3 & A4 & A5 & !A6 & !A7
# !A0 & !A1 & !A2 & !A3 & !A4 & !A5 & A6 & !A7
# A0 & !A1 & !A2 & !A3 & !A4 & !A5 & A6 & !A7
# !A0 & A1 & !A2 & !A3 & !A4 & !A5 & A6 & !A7
# A0 & A1 & !A2 & !A3 & !A4 & !A5 & A6 & !A7
# !A0 & !A1 & A2 & !A3 & !A4 & !A5 & A6 & !A7
# A0 & !A1 & A2 & !A3 & !A4 & !A5 & A6 & !A7
# !A0 & A1 & A2 & !A3 & !A4 & !A5 & A6 & !A7
# A0 & A1 & A2 & !A3 & !A4 & !A5 & A6 & !A7
# !A0 & !A1 & !A2 & A3 & !A4 & !A5 & A6 & !A7
# A0 & !A1 & !A2 & A3 & !A4 & !A5 & A6 & !A7
# !A0 & A1 & !A2 & A3 & !A4 & !A5 & A6 & !A7
# A0 & A1 & !A2 & A3 & !A4 & !A5 & A6 & !A7
# !A0 & !A1 & A2 & A3 & !A4 & !A5 & A6 & !A7
# A0 & !A1 & A2 & A3 & !A4 & !A5 & A6 & !A7
# !A0 & A1 & A2 & A3 & !A4 & !A5 & A6 & !A7
# A0 & A1 & A2 & A3 & !A4 & !A5 & A6 & !A7
# !A0 & !A1 & !A2 & !A3 & A4 & !A5 & A6 & !A7
# A0 & !A1 & !A2 & !A3 & A4 & !A5 & A6 & !A7
# !A0 & A1 & !A2 & !A3 & A4 & !A5 & A6 & !A7
# A0 & A1 & !A2 & !A3 & A4 & !A5 & A6 & !A7
# !A0 & !A1 & A2 & !A3 & A4 & !A5 & A6 & !A7
# A0 & !A1 & A2 & !A3 & A4 & !A5 & A6 & !A7
# !A0 & A1 & A2 & !A3 & A4 & !A5 & A6 & !A7
# A0 & A1 & A2 & !A3 & A4 & !A5 & A6 & !A7
# !A0 & !A1 & !A2 & A3 & A4 & !A5 & A6 & !A7
# A0 & !A1 & !A2 & A3 & A4 & !A5 & A6 & !A7
# !A0 & A1 & !A2 & A3 & A4 & !A5 & A6 & !A7
# A0 & A1 & !A2 & A3 & A4 & !A5 & A6 & !A7
# !A0 & !A1 & A2 & A3 & A4 & !A5 & A6 & !A7
# A0 & !A1 & A2 & A3 & A4 & !A5 & A6 & !A7
# !A0 & A1 & A2 & A3 & A4 & !A5 & A6 & !A7
# A0 & A1 & A2 & A3 & A4 & !A5 & A6 & !A7
# !A0 & !A1 & !A2 & !A3 & !A4 & A5 & A6 & !A7
# A0 & !A1 & !A2 & !A3 & !A4 & A5 & A6 & !A7
# !A0 & A1 & !A2 & !A3 & !A4 & A5 & A6 & !A7
# A0 & A1 & !A2 & !A3 & !A4 & A5 & A6 & !A7
# !A0 & !A1 & A2 & !A3 & !A4 & A5 & A6 & !A7
# A0 & !A1 & A2 & !A3 & !A4 & A5 & A6 & !A7
# !A0 & A1 & A2 & !A3 & !A4 & A5 & A6 & !A7
# A0 & A1 & A2 & !A3 & !A4 & A5 & A6 & !A7
# !A0 & !A1 & !A2 & A3 & !A4 & A5 & A6 & !A7
# A0 & !A1 & !A2 & A3 & !A4 & A5 & A6 & !A7
# !A0 & A1 & !A2 & A3 & !A4 & A5 & A6 & !A7
# A0 & A1 & !A2 & A3 & !A4 & A5 & A6 & !A7
# !A0 & !A1 & A2 & A3 & !A4 & A5 & A6 & !A7
# A0 & !A1 & A2 & A3 & !A4 & A5 & A6 & !A7
# !A0 & A1 & A2 & A3 & !A4 & A5 & A6 & !A7
# A0 & A1 & A2 & A3 & !A4 & A5 & A6 & !A7
# !A0 & !A1 & !A2 & !A3 & A4 & A5 & A6 & !A7
# A0 & !A1 & !A2 & !A3 & A4 & A5 & A6 & !A7
# !A0 & A1 & !A2 & !A3 & A4 & A5 & A6 & !A7
# A0 & A1 & !A2 & !A3 & A4 & A5 & A6 & !A7
# !A0 & !A1 & A2 & !A3 & A4 & A5 & A6 & !A7
# A0 & !A1 & A2 & !A3 & A4 & A5 & A6 & !A7
# !A0 & A1 & A2 & !A3 & A4 & A5 & A6 & !A7
# A0 & A1 & A2 & !A3 & A4 & A5 & A6 & !A7
# !A0 & !A1 & !A2 & A3 & A4 & A5 & A6 & !A7
# A0 & !A1 & !A2 & A3 & A4 & A5 & A6 & !A7
# !A0 & A1 & !A2 & A3 & A4 & A5 & A6 & !A7
# A0 & A1 & !A2 & A3 & A4 & A5 & A6 & !A7
# !A0 & !A1 & A2 & A3 & A4 & A5 & A6 & !A7
# A0 & !A1 & A2 & A3 & A4 & A5 & A6 & !A7
# !A0 & A1 & A2 & A3 & A4 & A5 & A6 & !A7
# A0 & A1 & A2 & A3 & A4 & A5 & A6 & !A7
# !A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & A7
# A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & A7
# !A0 & A1 & !A2 & !A3 & !A4 & !A5 & !A6 & A7
# A0 & A1 & !A2 & !A3 & !A4 & !A5 & !A6 & A7
# !A0 & !A1 & A2 & !A3 & !A4 & !A5 & !A6 & A7
# A0 & !A1 & A2 & !A3 & !A4 & !A5 & !A6 & A7
# !A0 & A1 & A2 & !A3 & !A4 & !A5 & !A6 & A7
# A0 & A1 & A2 & !A3 & !A4 & !A5 & !A6 & A7
# !A0 & !A1 & !A2 & A3 & !A4 & !A5 & !A6 & A7
# A0 & !A1 & !A2 & A3 & !A4 & !A5 & !A6 & A7
# !A0 & A1 & !A2 & A3 & !A4 & !A5 & !A6 & A7
# A0 & A1 & !A2 & A3 & !A4 & !A5 & !A6 & A7
# !A0 & !A1 & A2 & A3 & !A4 & !A5 & !A6 & A7
# A0 & !A1 & A2 & A3 & !A4 & !A5 & !A6 & A7
# !A0 & A1 & A2 & A3 & !A4 & !A5 & !A6 & A7
# A0 & A1 & A2 & A3 & !A4 & !A5 & !A6 & A7
# !A0 & !A1 & !A2 & !A3 & A4 & !A5 & !A6 & A7
# A0 & !A1 & !A2 & !A3 & A4 & !A5 & !A6 & A7
# !A0 & A1 & !A2 & !A3 & A4 & !A5 & !A6 & A7
# A0 & A1 & !A2 & !A3 & A4 & !A5 & !A6 & A7
# !A0 & !A1 & A2 & !A3 & A4 & !A5 & !A6 & A7
# A0 & !A1 & A2 & !A3 & A4 & !A5 & !A6 & A7
# !A0 & A1 & A2 & !A3 & A4 & !A5 & !A6 & A7
# A0 & A1 & A2 & !A3 & A4 & !A5 & !A6 & A7
# !A0 & !A1 & !A2 & A3 & A4 & !A5 & !A6 & A7
# A0 & !A1 & !A2 & A3 & A4 & !A5 & !A6 & A7
# !A0 & A1 & !A2 & A3 & A4 & !A5 & !A6 & A7
# A0 & A1 & !A2 & A3 & A4 & !A5 & !A6 & A7
# !A0 & !A1 & A2 & A3 & A4 & !A5 & !A6 & A7
# A0 & !A1 & A2 & A3 & A4 & !A5 & !A6 & A7
# !A0 & A1 & A2 & A3 & A4 & !A5 & !A6 & A7
# A0 & A1 & A2 & A3 & A4 & !A5 & !A6 & A7
# !A0 & !A1 & !A2 & !A3 & !A4 & A5 & !A6 & A7
# A0 & !A1 & !A2 & !A3 & !A4 & A5 & !A6 & A7
# !A0 & A1 & !A2 & !A3 & !A4 & A5 & !A6 & A7
# A0 & A1 & !A2 & !A3 & !A4 & A5 & !A6 & A7
# !A0 & !A1 & A2 & !A3 & !A4 & A5 & !A6 & A7
# A0 & !A1 & A2 & !A3 & !A4 & A5 & !A6 & A7
# !A0 & A1 & A2 & !A3 & !A4 & A5 & !A6 & A7
# A0 & A1 & A2 & !A3 & !A4 & A5 & !A6 & A7
# !A0 & !A1 & !A2 & A3 & !A4 & A5 & !A6 & A7
# A0 & !A1 & !A2 & A3 & !A4 & A5 & !A6 & A7
# !A0 & A1 & !A2 & A3 & !A4 & A5 & !A6 & A7
# A0 & A1 & !A2 & A3 & !A4 & A5 & !A6 & A7
# !A0 & !A1 & A2 & A3 & !A4 & A5 & !A6 & A7
# A0 & !A1 & A2 & A3 & !A4 & A5 & !A6 & A7
# !A0 & A1 & A2 & A3 & !A4 & A5 & !A6 & A7
# A0 & A1 & A2 & A3 & !A4 & A5 & !A6 & A7
# !A0 & !A1 & !A2 & !A3 & A4 & !A5 & A6 & A7
# A0 & !A1 & !A2 & !A3 & A4 & !A5 & A6 & A7
# !A0 & A1 & !A2 & !A3 & A4 & !A5 & A6 & A7
# A0 & A1 & !A2 & !A3 & A4 & !A5 & A6 & A7
# !A0 & !A1 & A2 & !A3 & A4 & !A5 & A6 & A7
# A0 & !A1 & A2 & !A3 & A4 & !A5 & A6 & A7
# !A0 & A1 & A2 & !A3 & A4 & !A5 & A6 & A7
# A0 & A1 & A2 & !A3 & A4 & !A5 & A6 & A7
# !A0 & !A1 & !A2 & A3 & A4 & !A5 & A6 & A7
# A0 & !A1 & !A2 & A3 & A4 & !A5 & A6 & A7
# !A0 & A1 & !A2 & A3 & A4 & !A5 & A6 & A7
# A0 & A1 & !A2 & A3 & A4 & !A5 & A6 & A7
# !A0 & !A1 & A2 & A3 & A4 & !A5 & A6 & A7
# A0 & !A1 & A2 & A3 & A4 & !A5 & A6 & A7
# !A0 & A1 & A2 & A3 & A4 & !A5 & A6 & A7
# A0 & A1 & A2 & A3 & A4 & !A5 & A6 & A7
# !A0 & !A1 & !A2 & !A3 & !A4 & A5 & A6 & A7
# A0 & !A1 & !A2 & !A3 & !A4 & A5 & A6 & A7
# !A0 & A1 & !A2 & !A3 & !A4 & A5 & A6 & A7
# A0 & A1 & !A2 & !A3 & !A4 & A5 & A6 & A7
# !A0 & !A1 & A2 & !A3 & !A4 & A5 & A6 & A7
# A0 & !A1 & A2 & !A3 & !A4 & A5 & A6 & A7
# !A0 & A1 & A2 & !A3 & !A4 & A5 & A6 & A7
# A0 & A1 & A2 & !A3 & !A4 & A5 & A6 & A7
# !A0 & !A1 & !A2 & A3 & !A4 & A5 & A6 & A7
# A0 & !A1 & !A2 & A3 & !A4 & A5 & A6 & A7
# !A0 & A1 & !A2 & A3 & !A4 & A5 & A6 & A7
# A0 & A1 & !A2 & A3 & !A4 & A5 & A6 & A7
# !A0 & !A1 & A2 & A3 & !A4 & A5 & A6 & A7
# A0 & !A1 & A2 & A3 & !A4 & A5 & A6 & A7
# !A0 & A1 & A2 & A3 & !A4 & A5 & A6 & A7
# A0 & A1 & A2 & A3 & !A4 & A5 & A6 & A7
# !A0 & !A1 & !A2 & !A3 & A4 & A5 & A6 & A7
# A0 & !A1 & !A2 & !A3 & A4 & A5 & A6 & A7
# !A0 & A1 & !A2 & !A3 & A4 & A5 & A6 & A7
# A0 & A1 & !A2 & !A3 & A4 & A5 & A6 & A7
# !A0 & !A1 & A2 & !A3 & A4 & A5 & A6 & A7
# A0 & !A1 & A2 & !A3 & A4 & A5 & A6 & A7
# !A0 & A1 & A2 & !A3 & A4 & A5 & A6 & A7
# A0 & A1 & A2 & !A3 & A4 & A5 & A6 & A7
# !A0 & !A1 & !A2 & A3 & A4 & A5 & A6 & A7
# A0 & !A1 & !A2 & A3 & A4 & A5 & A6 & A7
# !A0 & A1 & !A2 & A3 & A4 & A5 & A6 & A7
# A0 & A1 & !A2 & A3 & A4 & A5 & A6 & A7
# !A0 & !A1 & A2 & A3 & A4 & A5 & A6 & A7
# A0 & !A1 & A2 & A3 & A4 & A5 & A6 & A7
# !A0 & A1 & A2 & A3 & A4 & A5 & A6 & A7
# A0 & A1 & A2 & A3 & A4 & A5 & A6 & A7;
D0.oe = !CE1;
D1 = !A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
D1.oe = !CE1;
D2 = !A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
D2.oe = !CE1;
D3 = !A0 & !A1 & !A2 & !A3 & !A4 & !A5 & !A6 & !A7
D3.oe = !CE1;
@Caius: I've got a PAL20L10 I need to replace with a GAL. Is GAL20V8 a good substitute?
It seems ok for PAL20L8 (array is much smaller).
A GAL20V8 could fit in but it depends on how many product terms the PAL20L10 has, otherwise a GAL22V10 can do the job.If you want, send me the native PAL20L10 dump an I will look at it.
Ok, thanks.Which is the original dump?Is the chip you dumped a PAL20L10 or PAL20L8?
Ah, OK, got it.I will post here my GAL conversions in some time.
Here attached the PAL20L8 to GAL20V8 conversion ( I simply used the PALTOGAL program, most of times it does the job), test it and report feedback,
As for the PAL20L10 dump, a GAL20V8 would not fit it due different I/O arrangement so I'll try to adapt it in a GAL22V10, I will post later results.
  • GAL20L8.zip
