BOUNTY for Taito G-Net CF Conversions.
BTW, I think the Street Fighter EX games are off the table unless someone has a creative/realistic solution for getting buttons 5 and 6 working on G-Net. Pretty sure there are no harness pins. Button 5 could technically work over d/26 (CHAMMA style) but nobody would wire that up just for Street Fighter EX, and you'd still be missing heavy kick.
I tested Strider Hiryu 2; the first bug occurs in the setup menu it freezes when trying to enter the "Memory check" menu,
and then reboots automatically after the freeze.
There are 3P and 4P connectors on the front. Extra Buttons could be wired up!
Actually, I was thinking of building one myself, since the button layout for Rival Schools on the G-Net system isn't square, and this "L" configuration doesn't work for me. Still, go ahead and offer the *Street Fighter EX* setup as it is—that way, I can at least give it a try. :thumbup:
Thanks again!
I am fully down the G-Net rabbit hole at this point...
GarNET Launcher POC.
You'll be able to compile your own libraries or just download an img that is already built. Looking into exiting back to the menu by holding start, that kind of stuff. 8GB could definitely hold the full existing library, but some of the new Q-Sound/Yamaha/Namco conversions are a lot bigger.
Need to do a bit of work to get the existing conversions going.
https://photos.app.goo.gl/8uRupoQcgQnDjbSf7
WTH =O amazing stuff!
This is amazing! 🤩 I truly hope to see this project flourish.
It's amazing how fast you guys are moving! I can barely keep up with you ^^.
When you mention an 8GB CF card, do you mean that's the capacity needed to fit R-Type Delta on it, or simply that the motherboard is capable of supporting a memory card of that size?
Edit : Ahah, I think I got it after all, lol. @kyletwentytwo, please marry me.:joyful:
I have discovered that when playing *Chaos Heat* using a 64MB SanDisk CompactFlash (CF) card, the demo sequences suffer from severe lag.
Additionally, the game occasionally resets itself.
Outstanding!
常にSandisk ULTRA IIまたはTranscend x133カードを使用するようにしてください。私はたった今30個注文しました。:)
I tried using a 32GB SanDisk Extreme CF card I had on hand, but a system error appeared.
It seems this card is not compatible with the G-Net system.
I asked Gemini about my issue and got some interesting results.
It turns out that *Chaos Heat* is an early G-Net title—classified as a "V1" title—and it handles data retrieval differently than other V1 titles like *RayCrisis*, *Super Puzzle Bobble*, and *Flip Maze*.
It appears that this issue occurs because data is read more frequently and at more granular intervals compared to other titles.
Has anyone else experienced this same issue?
If so, I could be certain that the problem isn't due to a hardware failure on my end.
Is it possible to do conversions for Namco System 12 games?
Was wondering the same thing about ps1 based namco arcade board hehe
DDR Konami 573 would be awesome too, but the sound would need to be converted, inputs to jamma too (video mpeg also😅)
wow...that multi menu is crazy🤩
On the Taito G-NET, CompactFlash card issues aren't due to the brand, but rather to the operating voltage of the chips used during manufacturing.
It's a bit of Russian roulette, because SanDisk or other major-brand cards coming from AliExpress are often counterfeits.
Personally, I use "no-name" CompactFlash cards bought on AliExpress 5 years ago: out of the 15 ,
I bought of the same brand and in various capacities, only a single 128MB one doesn't work on the G-NET.
At the very least, my card was not purchased from AliExpress.
I obtained it from a reliable source.
