BOUNTY for Taito G-Net CF Conversions.
That could lead to accidental button presses during gameplay. It would be better to assign it to a long-press of the Start button.
That makes no sense, an unused input can't be pressed by accident, there's a bunch of em' on the 3/4p connector. The start button is more likely to be pressed wrong (seen it many times on MAME cabs..)
  • Like
Reactions: nem
@kyletwentytwo any chance to update the single releases? Many are missing compared to your list...
Also, maybe better/cleaner to use one of the unused inputs as "menu" instead of hijacking the start buttons and making possible game conflicts?
Will do later!
@buffi already figured out system 10 conversions :)
I thought I had uploaded all the singles that are on Garnet, I'll compare today and make sure to add any that are missing!
Reset could probably easily go on a button on the 3P harness that is never used, would that be preferred?
Will do later!
All single releases should be in sync in the drive now! I hadn't uploaded any of the previously converted games, so I added those as well.
Hello everybody!
R-TYPE DELTA G-NET is ready to be tested.
Thanx to all the ppl here, especially Kyle22 - already enjoying Gamshara - wow - what a money saver this port is.. pcb costs are very high for this one. Also BB.
This is sooooo rad. Just played for a while and it went very well, this game just oozes style!!
I did run into one issue with a checkpoint on the first stage; once loading back in, the music would play a little bit and then die. If I paused and unpaused, it would resume without issue. Took a little video here, hope it helps!
https://photos.app.goo.gl/Ams8pcDiGYuCLMSE8
Thanx! What Speed Setting does your cart show on FAT OK, SPEED xx, LOADING...
xx is of interest
Nobody needs on-board flash for games basically, as on-board flash is only for original GNET games for BGM - nothing more (ZOOM ZSG-2 WAVE & PRG)
Of course we could use it for some game extra data, but usually PSX games etc load games from disc to RAM
6MiB of Flash is not much for an arcade game to store data, Einhander needs 100x more for data!
Some games converted for the G-Net system (such as *Tondemo Crisis!*) appear to write certain data to the G-Net's flash memory upon their initial launch.
What exactly is being written?
Now Using Network Card for Ingame Logging :)
Now
xx is of interest
Speed 66 👍
What exactly does the number mean here? I flashed the game to my faster memory card and got Speed 55, had the same music issue on this one too FYI!
Speed 66 👍
EXP1_DELAY value of PSX Hardware - manages bus speeds and access times on CF-card loads. The faster the better.
please enable stats to 1 in system.inf - play over the music hangs 10 sec, reboot and send stats screen which comes before loading game.
Hello. Is there a way to change the language of *Gamshara* to Japanese?
Currently, it is locked to English, and it cannot be changed to Japanese via the test mode.
On the actual hardware, the language is apparently set using a DIP switch.
Additionally, I would appreciate it if you could also add the Japanese versions of *Bloody Roar 1 & 2* and *Mr. Driller 2*.
While playing "Mr. Driller G," the error "(Error f094)" suddenly appeared, and the system reset.
This issue occurred twice over the course of about two hours of gameplay.
I am reporting this because it is possible that the issue stems from the game having been converted.
I have never encountered such a problem with original, native G-Net titles.
Getting Ready for PRIMAL RAGE 2 with 8MiB RAM config - Thanx to @Hammy for sending me the ICs
Fixing my port from 2011
All future games feature a quick FULL RAM Test 4MiB or 8MiB at startup
R-TYPE DELTA gets an update tomorrow
Yes, I prefer the Japanese versions too at least there are no unpleasant surprises with censorship or that FBI logo cluttering the screen on startup!😅
Next build planning on having the choice of either 👍 region conversion versions are almost trivial so no big deal. If we get to the point in the future where we are hitting against 8GB I'll probably remove English versions (seems preferred) but that shouldn't be a problem for a while.
is there an 8GB limit or can we move to 16GB cards?
I do like your idea of loading these from folders so we can build our own sets or add to them later, but if that is not possible I wonder if an application can be made that would allow you to build the multi from .img files so people can pick and choose which games go in there and add new games when they come out rather than having to distribute the whole set every time.
