If you're also selling the motherboard, @8bitforlife has been looking pretty feverishly for one.Hi guys,
If anyone want my multi cart I will sell it to you for the same price I bought it of course.
Wise man! @Apocalypse might be interested, but he probably won't commit for a month or so.I keep the mobo with my King of Crystal. Thank you![]()
AMG0110BGood pics of the two different motherboards here: https://www.mvs-scans.com/index.php/Main_Page#BrezzaSoft_Crystal_System
I have one or each that work fine if you need me to check anything @Apocalypse. Will post the values of those components for you in a bit. What revision motherboard is it?
I made a cap map list, confirmed to be the same values on AMG110B by @ekorz hope it helps.AMG0110BThanks for your help.
Thanks.Hope this helps, values taken from the Crystal of Kings motherboard (AMG0110B)
C64: unpopulated
C75: unpopulated
Q2: A1266Y Transitor
Q3: C3198Y Transistor
I need to take a measurement of C61, is this doable using my multimeter?
Thanks @Derick2k but C61 is a ceramic capacitor.I made a cap map list, confirmed to be the same values on AMG110B by @ekorz hope it helps.AMG0110BThanks for your help.
Yup, just in case you were missing any of those.Thanks @Derick2k but C61 is a ceramic capacitor.
Legend!@Apocalypse C61 is 315nf on min
I hope you get it fixed! There are too few of these around as it is!Legend!![]()
So far I only replaced C61.If anyone has a good scan of the manual, looks like the component values are listed.
?@Apocalypse![]()
It is a stereo b103 pot and thankfully matches the footprint of a Gameboy Advance volume pot perfectly, you just have to bend the pins to fit through-hole instead of surface mount. New pot on the right, above, works great.
If that gives you hope, mine had 6 pads completely eaten by the battery leak. Since traces all went under the chip I decided to solder wires directly on the VRenderZero legs. So far so good, it's alive.Un fortunatly one of the sdrams pads was complitely ripped off when i removed the one near the jamma connector and i'm afraid that wiring patch will be a pain the arse to do, so ill just try with the one that is at least booting.
It doesn't XDIf that gives you hope, mine had 6 pads completely eaten by the battery leak. Since traces all went under the chip I decided to solder wires directly on the VRenderZero legs. So far so good, it's alive.Un fortunatly one of the sdrams pads was complitely ripped off when i removed the one near the jamma connector and i'm afraid that wiring patch will be a pain the arse to do, so ill just try with the one that is at least booting.
