Building a wall mount for control panels
twistedsymphony
NH, USA
I've got a ton of control panels and for the longest time I've wanted to hang them on the wall. I designed a few 3d printed mounts tried some from others but ultimately decided that it'd be a ton of work to properly space and align every panel. Then using drywall hooks.
I looked at a number of other options but eventually had the idea for a wooden rack. This would easily keep all the panels in alignment. One rack could handled a bunch of boards at once and I could mount the rack directly into the wall studs nice and secure.
I also wanted to be able to easily swap out the panels to use them.
It's a really simple design. Each panel takes up about 6in in height which is enough for the panel and a little extra to get your hand in there to remove or install it.
I bought some 4in by 3/4in poplar at my local hardware store. I cut two lengths to 74in and then 8 shorter lengths to 23 and 7/8th. The size of those shorter lengths is critical because you need just right that the sides of the rack line up with bolt holes in the panel. This size was really based around how much space I had on my wall but was enough for 12 panels.
The rack is a simple box with two extra horizontal supports for rigidity. Each horizontal support has a matching vertical support and these are used to mount the rack to the wall.
I used picture hangers to attach the panels to the rack. I found that the "10lbs" hangers are perfect and the 30lbs or larger hangers are too big.
Overall I'm super happy with the results. Some panels that are heavier on the back hang at an angle instead of flat. I think an improved design would maybe be to taper the face of the rack by 5 deg (so it's deeper at the bottom and more shallow at the top) or so to counteract this. Alternatively I might add some magnets into the sides to hold down the bottom of the panels and keep them all perfectly upright.
Total Material cost here was about $115 and 90% of that was the wood, it took me about 3 hours to put together and get it installed. Tools used were a skill saw for cutting the wood, a drill for pilot holes and the screws and a hammer to put in the hooks. Most hardware stores will cut wood for too so you could probably save yourself a little time having them do that for you. I didn't have exact measurements until I had material in hand.
I do plan on painting it, but I'm having people over tomorrow and didn't really have time to do that and let the paint dry.
Anyway I'm really happy with that result. Figured I'd post this if anyone else has a similar need.
The sad part is that this is less than half of my panel collection. Other Panels NOT on the rack:
2x more VOOT Panel
Another Pachinko Panel (one is for sale BTW)
A repo New Net City Panel
4x Outtrigger Panels
2x Aleck 64 Panels
2x Repo Monkeyball Panels
A Repo Forgotten Worlds Panel
A P1 Virtua Bowling Panel
A Paca Paca Passion Panel
A SFIV P1 Panel
A Sega Virtua Tennis 1P Panel
A Taito 2P Spinner Panel
Probably some other's I'm not remembering
Nice and easy. Love it.
Now you have to tell us what each one is for ;)
All but one of them is in my panel guide: http://solid-orange.com/1805
I'll let you guess which game the custom panel is for. Technically there are 3 games that COULD use that panel but I built it specifically for one of them.
Gotta assume its the Astro panel with the crane joysticks, and one of the 3 games is Ninja Gaiden, if it's wired up like it looks....although you wouldn't need the third button on the panel.
It'd be interesting to know what other games, cause in my head, I'm thinking things like Nova 2001's strafe button, or Xenophobe's Duck button, etc.
That's one of the 3.
That "crane joystick" is actually a Semitsu Joystick designed to fit inside candy cab panels
Ninja Gaiden was certainly the most popular game that used these. These specific Sticks were also used on Atari/Namco Assault, and a fat handled version was used on Sega's SDI (though neither of those are the other two games that this panel is suited for) They came in a few colors too, there are red variants as well as unpainted raw aluminum.
These push button sticks were definitely the hardest control panel part I've ever had to track down and that includes Ghox tilting spinners, Capcom spinners, loop 24 rotary sticks, and virtual on sticks. lol
The heavy panels like baseball. Do you think this style would correct the sag? Any good solutions besides mounting in game etc?
Man the Virtual On Twin Stick panel looks gorgeous
I actually just fixed up a Hori EX Twin Stick this week
Been playing VOOT on the 360 learning how to use them
Closest thing I'll ever get to playing in a real arcade
Holy Shit!
Learn something new every day....I've never seen those, and I imagine they'd be a bitch to find outside of Japan, and even if you could travel directly over there. It's not like it's a terribly difficult implementation, but the machining is pretty exact, and I'm sure even spare parts for them are scarce now.
The only controls I've seen for Assault were the typical flight yoke style, on the Atari American cabinet. Was there a kit released in Japan for that game that specifically used these, where the top buttons are the triggers? Got any pictures, cause that would be cool.
Thanks for sharing this, cause not many people will get to see any of these up close!
@twistedsymphony and @Mrhide - Thanks a ton for this...arcade history is so cool, and it's neat to see it shared here for everyone!
These LSX-31's would be a cool thing to reproduce, as they appear to be just the LS-32 base, with modifications.
so no more guesses on what game my button stick panel is actually for? 🤔
