I've got a pvm and a bvm, both Sony. The PVM syncs up with whatever I throw at it. The BVM is difficult with a couple.
I'm connecting the HAS v4.2 to the BVM with the 8 pin mini DIN to EuroSCART to female RGBS to 4x BNC adapter to BVM-129X and I can see a rolling screen from CPS2 and CPS3.
This setup does work with Analog NT mini, playstation, and gamecube with appropriate RGBS SCART cables.
I've tried using the HD15 cable to SCART, all 3 CSYNC settings, TTL, and the LPF.
I've confirmed the pinout is correct on the cable and tried the maintenance menu on the BVM. I have the other 129X with the HD15 and SCART socket, tried those as well.
I always get the rolling image that won't sync.
I've read the BVM and 129X can be finicky with the sync signal it wants but wanted to ask for help here to see if anyone has the same setup and has figured out how to get this combo to work.
thank you for your time,
-Dan
-Dan
