Can I Swap a neck pcb from a ms2933 to a ms2930?
tengugurl
Denver Colorado
Hi all!
Quick question, hopefully quick answer (lol probably no haha)
Looked at the pcb on the neck board they look very similar (haven’t checked resistor values and stuff) but, thought I should ask if anyone has swapped out a neck board from a different chassis model? (Aka my Nanao ms2933 to a ms2920)
Thought I’d ask :)
Thanks all!
Nope, it's similar but if you do that you're going to get a very loud spark show. Pin 4 does not exist on the MS9-29 board, but the tubes used in the MS293x need this pin. Otherwise, ~27kV will be present at pin 4 and will arc to nearby pins, likely pin 5 (through a multimegaohm resistor).
EDIT: I had misread, and thought the question was about applying an MS9-29 neckboard to an MS-293x series.
