@twistedsymphony I did the clock patch but the music stops after few seconds, it cuts out while effects are still going, you can hear it cracking for a sec and then die. (cut trace between the first truhole and oki pin 5, then wired directly to upper oki, pin 5, that is connected to pin 9 of the 74ls74an)
Sometimes the board even reset itself and won't boot for a while. If i remove 13H 27c160 the game works till the end (with only effects).
the 27c160 is good, verify was ok and i even compared to the rom after a dump, its the same exact.
I have used a 27c020 for the 14H sound program, and also tryed a 4001 (double writed), since there is a difference on pin A18, won't make difference.
Also checked my solders, they are ok, no bridges
The hell is that? Board was working flawless with Charlie and Magical.
I've also realized that NONE of my programmed gals, exept for the ones already present at 4E and 8F (Magical Drop) will work. However the programmed 5C with osman will do.
I have tryed anything i could find related to PLD's, joe mac, gonta 2, charlie ninja.. none of them works on my board. I don't get it.
I have dumped 4E and 8F of this Magical Drop and i could not find a match in any of the other pals, but i honestly know nothing about them so it's just a guess for me.
These were also working with Charlie Ninja (i did not changed them at all) and they are marked WF-02 and WF-00, not WH
