Several people asked for these so here they are. I will only be selling this as a DIY kit. Price is $50 plus shipping in the USA.
The kit is easy to assemble it is just busy work I do not have time for now. There are some surface mount diodes and I WILL go ahead and solder those for you. Then you will just need to solder the pins, through-hole diodes and Hirose kick connector. You will also need to make a cable to connect each pcb to the condenser. I can provide a CPS2 kick harness connector and pins so you can crimp your own wires if you are connecting to CPS2 pcbs. $7 per connector with pins. I may stock the other connectors to connect to CPS1 and directly to the condenser at a later date. Dupont cables will work fine for this also. Just connect them 1 to 1.
Fully assembled (you will assemble)
The kit will have the SMD diodes already soldered like the unit on the right
Harness not included
Here are the connectors you need to make your own harnesses:
11-pin: https://www.mouser.com/ProductDetail/Molex/22-01-3117?qs=UZEkBKezw1axL7poWLkkLA==
Pins: https://www.mouser.com/ProductDetail/Molex/08-50-0113-Cut-Strip?qs=Y0K5pK5Q/ZFXz3KE6V6whg==
Capcom Kick Connector: https://www.mouser.com/ProductDetail/Hirose-Connector/DF1B-34DS-2.5RC?qs=zOgoZG1CgI8tpp9tfLhHyw==
Pins: https://www.mouser.com/ProductDetail/Hirose-Connector/DF1B-2022SCF?qs=zOgoZG1CgI/OMpXysNqe0g==
