GeorgeSpinner
Does the cbox pictured have -5v?
I have not seen one that takes 12v that also converts to -5v.
Thanks but the cbox pictured in the OP is a big red PCB that looks nothing like yours. Unless that's some type of attachment I'm unaware of?Mine appears to. I’ll check it with a multimeter if I think of it when I get home.
Very cool! Thanks a lot!They broke out the JAMMA blade in later models. More pics below including board revs. Pretty sure this is the same maker? Could be wrong
Great point. What sort of problems might stem from this? Maybe I’m experiencing them already. I’m not very well-versed on all this stuff yet.Unsure about power alongside all the other connections traveling down the wires of that cable to the extension PCB.
That’s the main issue people face with cheap JAMMA harnesses (using thin wires for power).
Worth noting for sure.
I'm using the power supply that came with it. Works with everything so far.I just purchased this supergun pictured. So from what I read here, I would need a much better 12v power supply right? I also have a retroelectronik supergun but scart doesn't seem to work, and I can't find an NTSC encoder anywhere on the net. I had one built 10 years ago with a JROK encoder and my mom threw it out![]()
I bought it so I can dust off my tekken boards and my 246I'm using the power supply that came with it. Works with everything so far.
Everything = cps, MVS, taito F3, Double Dragon II, Rastan, Final Blow, Vigilante, hit the ice, super volleyball, and more.
I have this pictured below. Would that work? or can you send me a pic of the PCB passthrough. Also, would soldering off 11/M work as well?Cool.
Just make sure you read my post about pin 11/M.
