Ok, its time for an update.
I have gotten A LOT of messages regarding these conversions and some of them seem to be suggesting I've made this all up..
So here goes in trying to summarise what I've got working and what I think is a worthwhile conversion and yes sound does work. Is it perfect, probably not yet, but it certainly is worth doing from a shit footy board.. I did share all the information I could on this thread to try and explain what was possible from day 1, and it was an ongoing project, maybe some of it got lost in the pages as some messages from people seemed very confused.. I will update the original conversion info with all the later info on higher 4M game rom pals and the recent additional sound stuff I've worked out.
BUT firstly, a disclaimer, which I guess I should have said to begin with!!! lol,
"This conversion is for fun and to understand the hardware in greater depth, I am sharing what I got to work along with all the tech details I can in and in as much detail as possible, but it will be technical and questions via pm might not get answered if the info is already covered here. If you can't get it to work on your board then its NOT my fault and I am not making shit up. Thanks
So, onwards, 2 videos to share with graphics working and sound:
Gunlock -> https://www.instagram.com/p/CoriyjkIiUf/
Elevator Action Returns -> https://www.instagram.com/tv/Co7FM0woIkP
Info to add on the main conversion details post, but shared here first.
- 4M Pal.
For elevator action returns I wrote a new pal to get the larger game roms to work. Some later games have 4Mbit rom x 4 instead of 2mb (gunlock) or 1mb (footy). If you need this I can send you a chip. The chip fits into socket IC29. There isn't any additional address lines to connect or modify between the pal and game roms, taito already added everything. Once this pal is installed then you can leave it in for all games. ie it works for everything 1mb 2mb and 4mb. (This Pal is to do with Game roms NOT SOUIND!!! Please don't ask me about why this pal is needed, or why it doesn't make the SOUND work!!! Read the thread!!)
- Additional Sound conversion and changes.
After seeing some odd behaviour on light bringer I spent a lot of time looking at the Ensonic hardware on different platforms along with various schematics found online. I deduced the following which improves the sound access. I discussed this earlier in the thread before investigating it (need to find the post) on v2 game sound system having some missing sounds and/or sounds not playing correctly.
So The Chip labelled 5505 is called the OTIS chip and has outputs !RAS (pin31) and !DBUS (pin30) The !RAS line is fed to the MB8421 IO/RAM chip at IC20 pin1. This is the !CS line for the L eft part of the chip. the chip is 2 devices in 1 (Left and Right) This link represents the connection for v1 sound. However on v2 sound the link needs changing to be !DBUS instead.
See below for the jumper to add and the trace to cut
I also found that with this change the PAL at IC16 should be changed to D29-17-1
Making these 2 changes should help with certain sound/music stall issues being resolved and generally better v2 sound operation (see videos). Also it is important to get the correct PAL at IC14 to. This should be D66-09 and should be checked that it is programmed correctly ( Many people have done this wrong and thought sound was broken) . Again if you need this chip I can send you one correctly programmed. (Please don't tell me the chip doesn't need to be this version or that and you can use some shit chip from china...) See below
Hope this help get more boards converted.
Again if you need pals to use then get in touch.
