CPS-3 Custom METAL Case
is it better to have it right-angled or is it just to make it more compact?
It’s better for people not using a case, especially if mounted in a cab onto a PCB board. Keeps it compact.
I have a couple customers that asked me about laying the cart flat because they’re worried it’ll get snagged if they’re doing stuff in the cab.
I personally use Hursit’s cases, and when the cart bracket is ready I’ll be installing it to protect the cart. That way I will never take the cart off the motherboard. It’ll live there forever!
Hope you’re doing well @Viku !
Understood! Just bought 3 😱🫡💎
Hello people
The production already completed but aluminum company made a mistake of the Bottom parts. They RE-made them and will ship them to warehouse this week. I will start to ship them very soon.
Sorry it has been take very long, but i wanted to create the perfect Final CPS3 Case.
It supports the Darksoft Super Multi system. I created a PCB for the Game Selector.
NOTE: The aluminum Knobs will have Anodized. These are prototype samples.
Just got the case it's well built. Didn't need to use the LED wires but it's good that they're there. Unfortunately the game selection knob was not helping me, it just kept going between 4th strike and sf 3 new generation. Therefore I plugged back the dip switch for the darksoft Simms. Quick question is the volume knob and reset button supposed to be loose?
Y
you can get a piece of double sided tap on both so the stick in their respective places
Reset Button will loosen yeah, when you press it it will push the reset button. Sound Knob should be tight fit. But some Volume pots are different. You can use some double sided tape to make it thicker.
Please DM to me that Game Selector problem. I will check it to see whats going on.
Thanks.
I recently received the CPS3 metal case from @hursit , and it’s absolutely stunning! I’ve never seen a product of such high quality in a long time.
Nicee I just got mine in the mail too
One question, the LED logo should be solder to which voltage line?
round 2!
@hursit just got it all installed and the quality is incredible def love the case. The led looks great. But I am also having issue with dip selector. It is only bringing up 4th strike, street fighter 3, and third strike. Did you come up with a fix?
Edit: figured it out had ribbon cable upside down on selector went opposite way of how I thought it should go and plugs in both ways
